FOS Bud's Bait "N Gas Dock Challenge #2
Started by ACL1504, September 12, 2016, 04:29:00 PM
I painted the roof panels with full strength Floquil DH Gray to represent old galvanized panels.
Prior to gluing them in place, I used a file to file any glue the squeezed out from under the 2X4. I didn't want the panels to not fit properly.
The panels were then glued to the roof card.
All the panels are now glued in place.
When the gray paint is cured, I'll stencil the "Gas & Bait" on the roof panels.
Powersteamguy1790
Very nicely done on the floor planking and roof Tom. :) 8)
Polux
Quote from: Powersteamguy1790 on October 30, 2016, 03:06:20 PM
Thanks very much, I appreciate the support.
Quote from: Pol.lux on October 30, 2016, 03:26:33 PM
Nice work on the roof, Tom ;)
Polux,
Thank you as well. Much appreciate you following along.
Quote from: jimmillho on October 30, 2016, 03:47:04 PM
Tom, That is a cool looking roof.
Jim,
Thanks Butty, appreciate the compliment. This has been a fun build up to now.
Mkrailway
Tom, the structure will fit perfectly into your layout. For the dock, I often pad my finger on some chalk or dirt and grind it into the dock in areas. Thus also adds texture and some color dimension.
Can't way until is placed on the layout.
Marty
The roof paint dried enough for the "Gas & Bait" stenciling.
I fit the stencil flush with the bottom of the 2X4 and centered it on the roof.
I used Floquil Light Blue and applied the paint. I put some paint on a piece of cardboard. I used a pointed brush for the paint application, not the brush shown below.
The brush I used is one that I got from Micro Mark. It comes in a set of four and is referred to in the MM web site as dry brushing brushes. Karl S. put me on the the set.
Anyway, I held the stencil in place and worked one letter at a time from left to right. I basically dry brushed the light blue on the roof. I didn't pull the brush down but instead dabbed/stippled the paint on.
Quote from: Mkrailway on October 30, 2016, 05:40:37 PM
Marty
Marty,
Thank you and I'll try the finger chalk/dirt on the next dock, loading or other wise. Thanks for the tip. I'll add this to my tip list.
I'm anxious for it to get on the layout also.
At the Scranton, PA. Expo I picked up one of Doug's weathering powder kits. I guess I just wanted to support the hobby as I have enough weathering powders to last me a lifetime with out these.
I used the Burnt Umber and Raw Sienna to weather the roof on Bud's.
Powersteamguy1790
Very nice weathering Tom. :)
One thing I always do is copy the sign sheet in all kits I build. This is good practice in case you have a need for the original sign. I keep the original and use the copy for the structures. Another reason is that it gives my quite a few signs to use in different places and on other buildings.
I used an unused piece of chipboard and glued the sign on. When dry I cut the sign out of the chipboard.
I then framed the sign with 2x4's.
Quote from: Powersteamguy1790 on November 01, 2016, 04:04:28 PM
Thank you very much kind sir. I appreciate you following along.
