Got Bored II
Started by fsmcollector67, September 25, 2016, 12:10:54 PM
fsmcollector67
Well I got bored again, and wanted to see if I could make an HO scale bed.....here is what came out..
Thanks for taking a look.....
Loren....
9 Fingers Loren.....
rslaserkits
Rail and Tie
That is just jaw dropping beautiful!!
Darryl Jacobs
Inter-Action Hobbies
www.interactionhobbies.com
Quote from: Rail and Tie on September 26, 2016, 11:07:12 PM
I agree and it is also awesome
ak-milw
What everyone else said! Fantastic Work!
fsmcollector67
Thanks everyone, I really appreciate the great comments, glad you all like it...
Loren...
Hi Loren:
If that's not a kit all I can say is WOW!!!!!!!!!!!!!!!! What a great job.
Loren,
Ditto to all the other comments, wonderful.
Mike Engler
Quote from: postalkarl on September 30, 2016, 07:54:24 AM
Hi Loren:
Even if it is a kit it is great work!
mike.engler59@gmail.com
fsmcollector67
The bed was all scratch built from 1/16 basswood for the posts, hand sanded with 300 grit, and the frame, and headboard are 2x basswood. The lighter detail pieces are made from 1x basswood.
The first post took me about an hour and a half to figure out, and the others I was able to cut down to 30-40 minutes each. The sheet, and pillow are pieces of balsa covered with tissue painted with white, and off white paint. The hardest part was cutting the grooves in the headboard. I tried sanding, and cutting, neither worked. I than used a fine point in a dremel, and pretty much burned a little at a time, and finished with a jewelers file. It was fun to build, and really not that hard....Thanks again for all the great Comments....
Loren...
