rpdylan
Awesome! Following along so I can get pointers- I want to drop my track under the layout and come back up in another section....
Bob C.
Quote from: rpdylan on March 10, 2017, 09:11:46 AM
Thanks for following along.  The HOn3 line on my layout is the upper most level and runs between the four major groups of mountains.  At each end after making approximately a 80 foot run it travels down a helix with the return under the layout.  I have been working on and off for three months putting in all the track under the layout. I anticipate a long shake out period with the track work because it was hard to see under the layout.  We will see in a few weeks. The idea is to be able to run this continuously during open houses etc. The line can also be run point to point during operations.
Here are a couple pictures of something you shouldn't do.  When I laid the track in this area I put in a 28 inch radius S curve.  It really looks nice as a diesel locomotive pulls a train through the area.  Problem is the steam locomotives can't deal with the S curve - derail every time.  So one of my projects this week is to remove the S.  I can do it without modifying the location of the trestle - I just need to add a couple deck planks.  I used my radius gauges to figure out the new route.
As soon as I get the track work changed and tested I will be finishing the scenery in this area.
ak-milw
John, how do you plan on bending the trestle, or do you have to redo it?
Powersteamguy1790
Great photo's John. :) 8) Well done.
Quote from: ak-milw on March 11, 2017, 01:10:36 PM
Andy
All I have to do is add a couple planks to the trestle so no big deal.  The S was an after thought that did look cool but was not functional with the larger steam locomotives.
sdrees
To bad the S curve did not work out for the steam locomotives.  I added a lot of interest to this great scene.
Steve Drees
SP RR
Mkrailway
Can't you just flatten the curve near the embankment on the front left?
Quote from: sdrees on March 11, 2017, 06:24:22 PM
Steve
Thanks for stopping by - yeah it did look good but I can't have the big steamers having problems.
Quote from: MartyO on March 11, 2017, 07:28:21 PM
Marty
Tried that but it would require too tight of a radius coming off the big trestle.  It will work by straightening out the track between the two trestles. I had it that way in the first place and decided to get cute with the S curve. Thanks for following the thread. I'll post some pictures of the fix when I get it done.  I have some big pine trees already made up for the right side of the tracks.  The trains will be running through a forest of big pines when this area is complete.
Good save John.....I'm sure that scene will be great when you get it finished and you'll be much happier when your steamers run thru it without problems.  8)
