Shelby's Marine Service
Started by sdrees, March 02, 2017, 09:49:19 PM
sdrees
Jeff, I can't decide either.  Thanks for stopping by.
Steve Drees
SP RR
sdrees
Hi Mark, Jerry and Jerry,
Thanks for the compliments, much appreciate them.
Steve Drees
SP RR
Good work Steve.....I love the window that the stick is holding open.  8)
sdrees
Hi Greg,
It is all those little details that make things interesting.  Thanks for stopping by.
Steve Drees
SP RR
sdrees
I have been working on the walls for the bait shop recently. I wire brushed the clap board siding to provide the wood grain. Then I used Rembrandt pastels for staining the clap board. I then lightly sanded the siding to show wear on the edges of the clap board siding. I raised some of the ends of the siding with a No. 11 blade and used a pin to make the nail holes. I then used the damp brushing technique for the color coat and then several coats of a light A/I solution.
I placed the dry transfers. I was very lucky that the large ones came out OK. Also, I cut out some of the printed signs, sanded the back on the larger ones to make them thinner and worked them into the clapboard siding by using a No. 11 blade and cut them along the edges of the clapboard siding. Since the printed signs were glossy, I used a flat acrylic clear coat to dull them.
The bright red paint at the bottom on the first picture will not be seen once the walls are assembled.
After looking at the last picture, I am going to redo the trim around the door.  It is to wide.
Steve Drees
SP RR
rpdylan
looking real good Steve! your build is coming along nicely!  I need to experiment with using pastels for the base color, rather than for weathering.....I'm a "dry sponger"....
Bob C.
Hi Steve:
Looks great so far. Keep the pics flowing.
Steve,
Great job, love how the signs came out.  The contrast with some sharp new signs, and others old and faded is a really nice touch.
sdrees
I have erected the walls for the bait and tackle shop. I also redid the trim around the screen door.
Steve Drees
SP RR
Steve,
Very well done. Love the weathering and color.
Hi Steve:
Ditto on what Tom Said.
sdrees
Thanks Tom and Karl.  It seems now that I spend more time trying to make my models look old and dilapidated, than actually building the model. It is more time consuming to make a peeling paint than to do a sparkling new paint job. But it is well worth it.
Steve Drees
SP RR
Powersteamguy1790
Great build and weathering Steve. :) 8)
rpdylan
nice weathering effect on the trim.  The sign over the door came out great! Great work Steve!
Bob C.
