Shelby's Marine Service
Started by sdrees, March 02, 2017, 09:49:19 PM
Great modeling Steve, I really appreciate you showing us how you build the dio's and then place them in your layout, looking forward to when you do scenery to bond it all together.
sdrees
Steve Drees
SP RR
Steve,
Getting caught up on your build. Beautiful work, the water front looks wonderful.
sdrees
SierraWest Scale Models include many many castings in their kits that add lots of detail to their Here is a quick guide on how I go about it.  As you can see from the photo, I use many types of paint, Rembrandt soft pastels, Reaper acrylic paints, craft acrylic paints from Michaels and what ever other paint I may need.
The first step for me is to prime the castings with a spay paint.  For wood items, I spray the castings with a earth tone color. For metal items, I will use a gray colored paint.  In this case, I used an air brush.
I always use a piece of glass for my palette because it is so easy to cleanup.  I just use a straight razor blade to scrape the glass.
On the left side of the glass are powders made from the soft pastels.  In this case I used pastel numbers 408.3, 408.5, 408.7, various shades of raw umber, 231.3 a shade of yellow ochre.
I use alcohol to mix with the powder to paint all the wood surfaces on the castings.
Then I use the acrylic paint to paint all the little details of the castings such as wood and metal barrels, various tools, cans, buckets, parts, etc
I will then use an A/I solution and go over the whole casting and then let the alcohol dry.  I will then use various shades burnt sienna and add rust where I want it.
Once the casting is complete, I will then dust it with a light gray or earth tone to dull the colors so that non of them draws your attention.
These castings are completed.
Steve Drees
SP RR
Nice work on the castings, Steve.
Hi Steve:
The castings look great.
Mkrailway
Steve, you are getting along great with the build.
sdrees
thanks Jeff, Marty and Karl,  this is only about a third of them, and more to do.  Then there are some things that I want to update on the diorama to bring it into the early 1950's such as the stationary steam engine etc and the boat will be a powered with a diesel engine instead of sails. This will require more castings.
Steve Drees
SP RR
engine909
Steve, It is always a joy watching a Sierra West kit being built. You are doing some fine modeling.
Thank you for sharing. It is a very generous gesture.
ed
sdrees
I have been working lately on the loading dock, overhead crane pieces and the hoist house.  here are some progress photo's of the hoist house.
I have modified the front of the building because I am going to install an electric winch in it that will be able to be seen.
Steve Drees
SP RR
sdrees
Ed,
Thanks for stopping by and the nice compliment.
Steve Drees
SP RR
Hi Steve:
The weathering looks just great. Love the red you used on the walls.
donatode
What Jerry and Karl said.....only double!!
sdrees
I have been working on the fishing boat. This will be in the repair yard when the diorama is complete What I have done is add a prop and rudder to the boat. Also the cabin I made the walls out of 1/64" bass plywood and made several templates and wrapped it around and glued the plywood to them. The roof is 1/32" bass plywood.
Steve Drees
SP RR
