Schwarz Foundry - 2019 Challenge Build - aka FSM Sewall's Foundry
Started by S&S RR, January 02, 2019, 07:12:07 PM
Quote from: cuse on February 23, 2019, 08:18:57 AM
What a great looking structure! I love all the build threads because, as a relative newcomer to FSM kits, I've seen most of them in pics, but not as "intimately" as you get through a build thread. This is really nice. I'm looking forward to the weathering blast! Nice work!
Thank you for following along, there will be weathering.  This structure is way to clean to be a foundry.
Quote from: vinceg on February 23, 2019, 08:26:16 AM
As usual, the stone work and shingling look especially good.
Vince
Thank you for following along and the kind words.
Rail and Tie
John, I am really enjoying your build. Very clean work.
Question: In the last pic what is going on with the window frame in the lower left corner of the building?  Is that meant to be a rotted out window?
Keep up the great work as usual!  O and by the way, you picture lighting is always fantastic.
Darryl Jacobs
Inter-Action Hobbies
www.interactionhobbies.com
Quote from: postalkarl on February 23, 2019, 11:23:56 AM
Hey John:
Look great. I'm following along.
Thanks - great to have you along for the ride.
Quote from: Rail and Tie on February 23, 2019, 12:43:20 PM
Darryl
Thank you for following along and the kind words. Yes, the window casting that comes with the kit is a rotted out broken window and that is what I used. It will take some work with the weathering to get this just right.  This is a working foundry that needs some repairs.
Thank you for the comment on the lighting.  I have three LED spot lights above my workbench that are identical to the lights in my valiance on the layout.  I have to be careful, I sometimes put me and or the camera between the lights and the model when I take pictures and we end up with a big shadow across the model. You can see the shadow on the workbench but not on the model in some of the photographs on the last page of this thread.
I have completed as much of the detailing on build A and B as I can without mounting them to the baseboard.  As soon as I add the shingles and rafter ends to building C it will be time to glue them to the baseboard.
This structure will be weathered heavily since I have never seen a clean foundry and it's located in the center of a yard full of steam locomotives. Once this is mounted to the base board the chalk dust will be flying.
John, looking very good in all the details. The shingles are a standout for me.  Beautiful!
--George
Really, George Sellios?  A stone overhang?  There'd have to be some heavy duty framing underneath that.  (I remember discussing overhangs with Jim Mooney of Bar Mills.  I have the Cundy hotel and I said I wanted to replace the wood siding with brick, more in keeping with my city.  Jim said, "How will you do the overhang?  There'd be a lot of weight underneath all those bricks."  I'm still pondering that.)
Coloring looks great!
Quote from: Opa George on March 02, 2019, 08:39:47 AM
--George
George
Thank you for the kind words and for following along.
Quote from: deemery on March 02, 2019, 09:38:37 AM
Dave
Someone slipped the building inspector some C notes on this one, but it sure does look good.  I just corrected two of them and in my mind added 8 inch I beams under the overhang and then covered them with wood. ;) [size=78%]  [/size][/size]The two I corrected where with the dormer.  The roof was flat or slightly running back against the slope of the main roof - I recut it and gave it some slope.  The other was George had the metal roofing that was there, because of the leak caused by issue one, running horizontally. My metal roofing runs with the slope of the roof.  George is an artist - and usually he is modeling something he saw. Sometimes it's something the building inspector missed. I know George, with his later kits, would have people look at his kits and "make sure I didn't do something wrong with the mechanical stuff". [size=78%][/size]Probably because someone let him have it on some of these earlier kits. [size=78%]
When building an older FSM kit (#100, Jacob's Fuel), I was struck by what a great draftsman George is.  But I'm sure my father would point out that being a good draftsman doesn't necessarily qualify you as a structural engineer :-)
(And on the Cundy Hotel, I'm thinking about a brick barrel vault and stone pillars.  That probably has enough strength.)
