Shadowlands and Tellynott
Hi guys.
Photo 1 - Here I am making up the side walls for the enclosed conveyor to transport the catch of the day from the low wharf up to the old fishery factory.  This was the only photo I took of the tower construction.  I was obviously on a mission that day!
Photo 2 - This is the original plan of the set of stairs to the second story door on the side of the tower.  As I got halfway through the build I changed my mind.
Photo 3 - The half way point.  I made up the lower string of stairs and they fitted perfectly, height wise, at right angles to the landing.  I though the looked good this way and it was much easier.
Photo 4 - The second string of stairs in place with 4x4 posts attached.
Photo 5 - Hand rails and kick board in place.  If I can deal with the fiddle frustration I like to meet some sort of health and safety rules.  Kick boards are a must in my modelling world, and I do think the stairway looks more complete with some sort of midway 4x2 handrail.
Photo 6 - I made up three of these little sub assemblies as a kind of scaffold to hold fishing nets.  Inspired by one of Gregg W.'s models...
More soon, cheers, Mark.
Howdy Mark,
The dock looks amazing.  I especially like the staircase and enclosed conveyor.
Great looking staircase Mark. The way you did it gives it much more eye appeal.
Thanks very much, Mike and Curt.
I'm pleased you approve of my efforts.  Curt - I agree with your thoughts on the stairway.  When I held it that position that is exactly what I thought.
Hi guys.
Photo 1 - Shows the tower in position on the layout.  I will build an aerial jut out at the back of the old fishery for the enclosed conveyor to join.
Photo 2 - A close up shot.  You can see I have added the fly rafters and rafter tails.  I add a piece of low tack painters tape with markings drawn on it to the roof for positioning of those rafter tails.  Fly rafters are positioned at the very extremities of the roof to support the overhang.  In the prototype these are strengthened by outriggers running at right angles from the first rafter/ truss into the building, across the top of the gable wall and out to the fly rafters.  These outriggers would never be seen on this model, so I did not add them.
Particularly for that unit at the dock, I'm thinking there would be an elevator to move the fish vertically to that diagonal walkway.  And that's an opportunity to add wiring around the structure.
Just really a great job.
Especially those stairs!!
Michael Hohn
Real craftsmanship throughout.  I like the complexity of all the different levels, stairway, conveyors, and roof lines.
Quote from: deemery on May 27, 2026, 05:21:07 PMParticularly for that unit at the dock, I'm thinking there would be an elevator to move the fish vertically to that diagonal walkway.  And that's an opportunity to add wiring around the structure.
Thanks, Dave.
Duly noted.
Quote from: Michael Hohn on May 28, 2026, 11:29:53 AMReal craftsmanship throughout.  I like the complexity of all the different levels, stairway, conveyors, and roof lines.
Thank you Mike, Philip and Jerry!
Its been a fun project.
Mark, the stairs do look very good.
The right end of the conveyor doesn't look like it's connected to anything.
What will go there?
My apologies if this was explained elsewhere.
Mark nice looking scene!!!!
Thank you Rich and Larry for your comments and for following along.
Rich - briefly explained.  The longer version is that I copied the mock-up when building the tower and enclosed elevator up to the old fishery.  When completed, I took it out to see how it looked on the wharf and discovered it was way too far forward on the wharf, leaving no room for pulling up the catch of the day.  My solution will be to add a hanging protrusion to the rear of the old fishery that the enclosed elevator will connect to.  This will leave the tower further back from the front of the wharf, as shown in the photograph.  And, as you noted, I have not done this yet.  We were away in Dunedin for dog shows, hence my tardy reply...
Hi guys.
A little tangent today...
I have been starting out on my tree adventure.  Shadowlands will need a LOT of trees!  There will be several different varieties and several different grades of each sort.  I decided to start off with swamp kahikatea's (white pines).  I haven't got to the adding foliage stage, but thought I would show you my method for creating trunks and adding branches.  Nothing groundbreaking, but a few tweaks.
Photo 1 - Swamp kahikatea, Ship Creek, South Westland, New Zealand.
Photo 2 - I have been using 45x19 dressed pine (probably kahikatea) for this.  I mark the tree outlines - I like to add a bit of curviness for interest - and then cut these out using my jigsaw.
Photo 3 - The timber is turned around in my vise to finish off the other end.
Photo 4 - Here is what I get out of a 200 - 250mmish length of pine.  If I want a curve both ways, four is all I will get, if I am happy with straight the other way I can cut each trunk in half the other way to produce eight trunks.  This would make the trunks around 9mm in diameter, which is around 2'8" scale feet.
Photo 5 - I then use the curved end of my belt sander to sand off the sharp edges.  I work my way along the length of the tree turning the trunk backwards and forward.
Photo 6 - This leaves variations in the trunk thickness, which I like.  Kahikatea trunks are fairly consistent in width, with only a slight tapering with height.  Branches are generally in the top third of the tree.  I then drill a hole in the base of the tree, add a nail, and grind this to a point on my grinder.  The trunk is now ready for the next stage.
