Build 001: KC's Jack Em Up Tire Repair
Started by PainTrain, August 23, 2019, 12:14:46 AM
PainTrain
New to modeling.  Here's the first kit I've been working on over the past month.
Lots of mistakes have been made, but I'm learning a lot.  I'm going to try to wrap up the windows and the roof this weekend so I can finally get around to weathering.
Rail and Tie
Welcome aboard Pain!
You will find an excellent support group here to help you with your structures addiction. Ask for any advice or comments. Great start for your first build. I must ask though, did you paint the window mullions /  trim after installing the glazing on the doors? That would make it a lot more work to try to stay within the lines.
Looking forward to seeing what you do with weathering.
D
Darryl Jacobs
Inter-Action Hobbies
www.interactionhobbies.com
Welcome aboard.  Lots of friendly modelers here.  Wondering how you plan to approach the weathering, guess I need to stay tuned.
Welcome to the forum.  It looks like you are off to a great start with this project.
Dennis Bourey
Dennis Bourey
dpbourey@comcast.net
Lake's Region RR
(Happy Modeling)
Welcome!  Glad to have you on board and sharing your build with us.  Great group of modelers here and you can't beat the price of admission.   ;)
Bruce Oberleitner
Welcome to the Forum!
I like those KC workshop kits as well.  There a great value for their price
BTW, the only mistake is not starting at all.  The only way to get better at something is to keep trying.
;D ;D ;D
Keep up the good work and ask anything you want.
I think there's a bit too much contrast between the black tar and the grey tarpaper.  Suggest you tone it down by working a dark grey pigment across the entire surface.  (Cigarette ashes would work for that, if you happen to have a source. :-) )
Welcome and thanks for posting this kit. I like it!  I haven't been on the forum nearly as long as most of the others here, but found a home a safe place to post pics and get constructive feedback.  Great community here, and I'm looking forward to seeing more from you.
--Opa George
Hey pain:
Welcome aboard. Will be following along. Nice kit.
PainTrain
Hey everybody, thanks for the warm welcome.
I painted the pieces individually with exception to the wall which I glued the corner trim in first then painted when the structure was glued together.  I think next time I'm going to to each wall separately through the weathering process, assemble, then fit the trim so I don't have gaps.  Also, the roof was quite the process.  I should have glued the stock to the structure, then added the roof detail, and used less glue.  Got quite a bit of warping.  The detail parts didn't come out clean due to the fact that I painted them on a flat surface and got quite a bit of pooling.  I tried cleaning it up but the xacto took some of the plastic off in the thinner areas.
I patched the area where no card stock was provided using a USPS envelope.  Next I'm going to fit the roof trim, smoke stack, and paint the light now that I've got my hand drill.
As for the roof paint, I definitely agree.  The grey paint came out a lot lighter than I anticipated so I plan on hitting it with quite a bit of grime to tone it down.  Also, the trim pieces were painted with a maroonish color that doesn't contrast well with the brown I chose for the walls.
The next kit I do, I'm definitely going to paint some spoons to see how well the colors contrast with each other so I get results that are a little more pleasing.
This kit definitely isn't for beginners, but it's still been fun putting it together.
That fan on the end wall is cool!
Yep, fun is the name of the game.
--George
PainTrain
Thanks George
Added trim, played witha different color on it, and started weathering the roof.
