FOS REA Building, kit bash and scratch build.
Started by ACL1504, November 12, 2023, 04:27:10 PM
I've learned to do the casting details first. With past builds, when I finish a model I'm not in the mood to file, clean and paint the detail casting.
So, I filed off the excess flash, cleaned the casting in warm soapy water and set aside to dry. This afternoon, prior to the rains, I used rattle can auto primer to prime the castings.
For the three smaller chimney pipes, I drilled small hole in the stir stick. I placed the chimneys in the holes to hold them while spray painting.
I started this build with a new cutting mat as well.
Over several days, I spent quite some time going over the instructions and the parts. I set aside the wood pieces I WILL NOT be using.
I decided to start with the main building. This building is three stories including space for an attic Part of the lower floor houses the office.
I used a #17 Xacto blade to cut the pieces from the carrier sheets.
After the main pieces were removed, I numbered them on the rear. Not that they can get mixed up but it is just something I got in the habit of doing.
After looking at the width of the main structure, I didn't think it was wide enough for my needs. I wanted it a little wider. In the photo below, you can see how narrow the structure is.
I needed to cut two new end walls to make it the width I wanted.
I used new Northeastern Lumber scribed siding for the new walls. I opted to go with a random scribed siding as well.
The next photo shows the rear of the old and new wall material.
The new scribed siding wasn't square on the end so I used a metal square and trimmed off the end to make it square.
The new random scribed siding is on the right and the kit walls on the left in the next photo.
Back in a few. Time for a cold Diet Pepsi.
I increased the width of the building by 8 HO scale feet. I marked in pencil on the rear of the wall where the doors and windows will be located. I used the old wall for the original kit and then added the other windows.
Referring to the next photo, you can see I added a larger office window on the bottom between the freight door and the office door. I also changed the larger doors on the right and added more windows.
Fast forward and the new walls now have the new window openings.  The windows and door were also test fit into the openings.
Old wall on right.
I also cut the new freight house end wall.
Done for today.
Hello Tom, it's great to see you back on the forum, although I was watching your progress on the other forum as well. Wonderful and informative work as usual.
Quote from: nycjeff on November 17, 2023, 05:12:11 PMHello Tom, it's great to see you back on the forum, although I was watching your progress on the other forum as well. Wonderful and informative work as usual.
Thank you, much appreciate you following along.
Jim Donovan
I had forgotten how thoughtful you approach modeling, an area I can learn much. I can't remember the number of times I find myself asking, 'where the h@ll did I put it!' I like the idea of detail work first, I too am not in the mood to work on the parts after getting the structure done. They bring the building alive but require a lot of attention and time.
As usual learning a lot, thanks.
Holland & Odessa Railroad
Quote from: Jim Donovan on November 18, 2023, 07:36:51 AMI had forgotten how thoughtful you approach modeling, an area I can learn much. I can't remember the number of times I find myself asking, 'where the h@ll did I put it!' I like the idea of detail work first, I too am not in the mood to work on the parts after getting the structure done. They bring the building alive but require a lot of attention and time.
Jim,
Thank you and I'm happy you are enjoying the build.
I'll have more to share as the thread continues.
I thought as long as I was changing the walls, I may as well go ahead and change the walls on the small sub structure on the rear of the building. This way all the walls siding will match.
I used the kit walls as a template and cut the one long and two short walls with the new random siding.
The numbers shown in red are the Tichy Train window stock numbers. I keep the blanks for use when scratch building. This way I can lay out the walls with the blanks to see what size window looks best.
I then added nail holes using the Micro Mark small ponce wheel. I again test fit the windows to see how they looked with the nail holes.
I didn't show the photos where I braced the back of all the wall sections. I think everyone has seen wall bracing before.
I used Hunterline Light Gray Mix (A&I) to stain the walls. I applied only one coat of stain. I wanted the weathered look after adding white which I'll show later in the build. By adding a second coat of light gray stain, the wall would be much darker.
I used a soft 1/2" brush to apply the A&I mix. I set all the walls aside and let dry at least 24 hours.
