Tom looks great so far.
Always nice to see a mistake and you go back and fix it!
It makes the next guy more careful.
Quote from: Jerry on December 30, 2024, 12:02:25 AMTom looks great so far.
Jerry,
Thanks you, much appreciated. Mistakes I can make and hopefully the repairs as well.  ;D  ;D
Time to work on the rear wall section. I want to have exterior stairs on this wall.
I need a set of stairs that will serve the second and third floors.
I don't want to cut the front of the wall section so I drew the two doors on the back. So the stairs are correct on the exterior, I needed to draw the doors and stairs on the opposite on the rear.
Dang, I went and did it again.  :-[  I cut the door size to large as you can see.
For this fix, I used a 2X4 and glued it to one side if the door opening.
Now this is much better.
I set the door in place to hold the 2X4 until the glue dried.
Once dry, the 2X4 was cut and sanded flush to the rear of the wall.
Back in a few, need to get a cold Diet Pepsi.
As I was still working on the rear wall, I added bracing to the front and two side walls. I used HO scale 8X8's for the wall bracing.
I've mentioned this on past builds but will do so here as well. I cut a piece of strip wood at an angle and use it to run along the edge of the bracing to remove any glue that may have squeezed out.
This isn't a necessary task but I like to have neat bracing on the interior even it it will never be seen.
I extended the bracing on the front to cover the lower portion of the front wall section.
This also gives me an area to glue the lower wall to the bracing.
Good move on the bracing to hold the shop fronts into position.
 Tom, this scratch build will be a nice looking addition to the A&S RR !
Tommy
Quote from: deemery on December 30, 2024, 04:12:07 PMGood move on the bracing to hold the shop fronts into position.
Yea, it was pretty much a requirement for the support of the front.
Quote from: tom.boyd.125 on January 01, 2025, 05:55:50 PMTom, this scratch build will be a nice looking addition to the A&S RR !
Tommy
Tommy,
Thanks you, much appreciated. I'm glad that I will be able to fit it into the area.
