Scratchbuilding a PRR 'FM' 40' flat in HO brass
Started by jbvb, January 02, 2025, 01:18:50 PM
Thanks, Tom B, Tom L and Dave.  I've helped judge a few NMRA contests and I've already got one Merit Award for a lightweight sleeper built from car sides on a core kit. With rivets and light weathering but without a load I'm fairly sure of 88+ points. I'll have a better idea after I do the SoQ. But this is only the first of four scratchbuilt cars required, regardless of the sleeping car.
Bernd
Nice work James. Impressive to see somebody else work in brass. Good idea also to use brass for an empty car.
Bernd
Last night I studied my Archer and Micro-Mark rivet decals.  Archer didn't make the 6" rivet spacing the FM plans show, but Micro-Mark does.  MM's instructions suggest using  an acidic "decal setting solution" first, then a "decal solvent" after everything is in place..  I read this as Micro Set and Micro Sol, but I don't have either on hand, just Walthers Solvaset.  So I could try out the Internet's thinking that vinegar diluted 8:1 with water will substitute for Mico Set, or I could drive 30 miles to a hobby shop.  Anyone with experience or opinions?
Quote from: jbvb on January 07, 2025, 10:51:47 AMLast night I studied my Archer and Micro-Mark rivet decals.  Archer didn't make the 6" rivet spacing the FM plans show, but Micro-Mark does.  MM's instructions suggest using  an acidic "decal setting solution" first, then a "decal solvent" after everything is in place..  I read this as Micro Set and Micro Sol, but I don't have either on hand, just Walthers Solvaset.  So I could try out the Internet's thinking that vinegar diluted 8:1 with water will substitute for Mico Set, or I could drive 30 miles to a hobby shop.  Anyone with experience or opinions?
Now that's -rivet counting!-  ;D
I thought it was pretty obvious on the plans, but then again I've been the junior member of contest judging teams.
Here's the PRR "FM" flat car with the first decals removed.  No reason to repaint till the rivet decals are added.
And here the Micro-Mark decal rivets are in place:
Here I've repainted the car from my ancient Floquil Boxcar Red.  It's a can I got from the estate of a guy in town I hadn't known was a modeler. I'm probably 10 years too young to have seen Floquil in paint cans in hobby stores.  But at about 65, the can still seals far better than anything I can buy hobby paint in today.
Here the Speedwitch decals are ready for dull varnish.  They weren't too delicate for Solvaset.  I chose the number as a car still listed as in interchange service in a 1966 ORER.  At least 50 years old then.
Howdy James, I have enjoyed your metal work and am happy to see you continue here.  The flat car is outstanding.  The rivets set it off.  Nice work.  Have fun, mike
Thanks, Tom and Mike.  Today wasn't too cold to airbrush with the attic window open; I got out the old Scalecoat Flat Clear and sprayed the painted surfaces of the car.
It needs brushed weathering on the trucks - journal grease, spring rust, brake dust etc. I'll probably finish with chalks on the body and deck.
#42
With a little weathering using pastel dust and a stiff brush, PRR 473078 earned 102 points at the NER Concord Flyer convention.  This is my 2nd Merit Award in the Cars category, so 2 more and 4 other superdetailed cars would earn me that AP Certificate.
