Clearwater Valley Railway Co.
Ron I looked at those when I was building my layout and was worried about their durability and hooking the plastic rod to the fascia, being not very mechanically inclined.
Quote from: Rick on July 15, 2026, 08:22:14 AMRon, great news on the layout clean up and maintenance.
I hope there will be updates on new layout progress soon.
Thanks Rick,
There will be layout updates soon, I have incentives.  ;D  I'm part of a model railroad tour in mid-October, I have a deadline.
Quote from: Philip on July 15, 2026, 08:57:04 AMRepairs are sometime mind soothing! Carry on! ;D
Thanks Philip.
And sometimes repairs can be a real pain.  ;D  Fortunately the repairs were not the pain kind.
Quote from: deemery on July 15, 2026, 09:21:56 AM
Quote from: elwoodblues on July 14, 2026, 09:02:24 PM
Quote from: deemery on July 14, 2026, 10:35:08 AMRon, how did that switch machine fail?  A piece of plastic broke?  General disintegration of the plastic?
The Bullfrog Switch Machine is made from wood that you get to assemble.
The assembly holding the throw rod de-laminated.  I assembled a new one to replace it.  I did manage to glue the original one back together, so I have an assembled spare for future use.
"de-laminated" - that sounds like a materiel failure.  Tim should send you a replacement for free...  Seriously, you should let him know about that.
De-laminated was probably the "wrong" word.  The pieces separated.  It was one of the first ones I assembled and after review I'm classifying it as "builder Error" as I "might" missed a glue joint.
Quote from: elwoodblues on July 15, 2026, 11:33:06 AM
Ah, that makes me feel much better.  "disassembled" rather than "delaminated"  ;D
Quote from: PRR Modeler on July 15, 2026, 10:26:40 AMRon I looked at those when I was building my layout and was worried about their durability and hooking the plastic rod to the fascia, being not very mechanically inclined.
I bought them when Fast Tracks first came out with them and I bought enough to do all the turnouts on my layout.  That was before I got into servos and planetary stepper motors.  I used the plastic rod method for the turnouts that were not parallel to the fascia and used  0.093 rod (with a 4-40 threaded ends) for the turnouts that are parallel to the fascia
I have been happy with their operation.
I think the first marketed switches were plastic?
Ron,
Congrats on the clean up and maintenance. I'm not sure which one is better, the constant maintenance or as you said the deferred maintenance method. I've done them both but get more satisfaction our of the deferred method.
Quote from: Philip on July 15, 2026, 10:03:21 PMI think the first marketed switches were plastic?
Philip, it you are talking about the switch machine from fast Tracks, I believe that they were always wood construction.
Quote from: ACL1504 on July 17, 2026, 02:17:30 PMRon,
Thanks Tom,
The deferred method does let you fix the problems all at once rather than when they arise.  Not working on the railroad for 13 years is almost criminal.  ;D
Quote from: elwoodblues on July 18, 2026, 09:54:59 AM
Thanks Tom,
13 years!!!!  Your lucky they didn't put you in jail!!!  ;D
Finally, it's time for another update. . . . .  ;D ;D ;D
Now that the turntable is installed it was time to install the turnout leading to the staging yard.
After stripping out the scenery and ties at the replacement site I cut a turnout template so I knew where to glue down the wood ties.
Before gluing down the ties I cut out the slot required for the turnout motor that will eventually get installed.  Seeing it's is by itself I'll probably use a tortoise that I presently have.  I do plan to install a 12v and a 5v bus to power the accessories on the layout.  I plan to use a recycled computer power supply to achieve this.
The ties glued in place.  I use white glue (PVA) to glue the ties down.  If I need to make changes, a little water releases the glue to make the tie removal easy.
The ties stained and the rails cut to size.
The turnout spiked in place.
The back end of the turnout spiked in place.
An overall view of the installed turnout.
Now that the turnout is installed the curve through the great divide seems to be too sharp.  I'll have to see how much I'll need to enlarge the existing hole, but that is a tale for another day.
Thanks for looking in.
Outstanding work Ron!  You must have patience to make your own.
Ron, nice job making the switch.
I guess moving it to the left is impractical at this point.
Regardless, I know you'll get the hole corrected.
