As Russ would say, Satisfactory!
Quote from: Pennman on July 05, 2025, 05:05:05 PMYou know Jerry, that I now have silverwood stain. I might just have to use some to see if I can achieve what you have shown us. Those wood planks are superb! I know lighting is also a small problem, but the dock pictures (shown earlier) look a little darker than the outside wall pictures, or it may be my eyesight. I was thinking that silverwood stain would be more darker though.
And Larry is correct when saying that you are the master of framing. How did you make the door rollers/pulleys?
Thanks for the nice compliment Rich.
The dock is darker only because I used a dust powder over the silverwood to make it look more worn.
And just so you know I used a brown paper bag on the walls.  Lightly rubbing to get a higher sheen.
Rollers are from a SW kit.
I still need to the weather the outside walls a little bit yet.
Quote from: PRR Modeler on July 05, 2025, 05:17:11 PMJerry everything looks top notch. Love the framing and the colors.
Thanks Curt glad you like the coloring & framing.
Quote from: Rick on July 05, 2025, 05:43:47 PMJerry, inside and outside colors look excellent.
And so does the peeling paint.
Rick thank you it's always appreciated to hear from you.  And such a nice compliment.
Quote from: elwoodblues on July 05, 2025, 07:48:46 PMJerry,
I see the master framer is at it again.
Great job on the walls and doors, I'm thinking I need to gewt some of that silverwood stain.
Hey Ron thanks for the compliment.  Not sure I'm a Master at framing but I sure do try.
You should try the Silverwood.  It really does a nice job for aged wood even for an undercoat.
Quote from: Philip on July 05, 2025, 08:54:18 PMAs Russ would say, Satisfactory!
Oh my God!!!  Unc is alive and well!!
Thanks Philip now that's a compliment!!
Howdy Jerry,
The aged white looks fantastic. Nice work on the interior framing.  Your masterful skill is producing a marvelous model.
Quote from: friscomike on July 06, 2025, 01:34:49 PMHowdy Jerry,
Thanks Mike it's appreciated.  Hopefully when I try to weather the walls it will all come together nicely.
One thing I forgot to mention on the Silver Wood the more coats the darker it gets so be wise when putting it on.  I usually wait to make sure it's dry before doing another coat.
Quote from: Jerry on July 06, 2025, 04:27:25 PMOne thing I forgot to mention on the Silver Wood the more coats the darker it gets so be wise when putting it on.  I usually wait to make sure it's dry before doing another coat.
Jerry,
Thanks for the tip on Silverwood. I'll keep this in mind when using mine.
Jerry,
I agree with the other comments on the dock and framing of the structure. The Silverwood stain on the exterior board is weathered perfectly.
Well done on all of this build.
Thanks Tom always happy to see you commenting on a project!!
Just a small update.  Putting the details on the walls before assembly.
There is still more to do.
The carpenter tools came from Alkem Scale Models.
They are really well done.
Last picture is the start of a workbench.
Wow! Wood planes, wood clamps and well-painted tools!
And a fantastic work bench. You have been busy Jerry.
Quote from: Pennman on July 13, 2025, 10:38:16 PMWow! Wood planes, wood clamps and well-painted tools!
Thanks Rich it's appreciated.
