2-6-0 Camelback with sound
Started by Philip, July 06, 2025, 06:52:09 PM
Quote from: Larry C on July 07, 2025, 08:02:44 AMPhilip OUTSTANDING!!!!!!!!!!!!!!!!!!!!!!
Like a cow, outstanding in the field! ;D
Thanks Larry!
Nice install.  I attach the speakers and other components with silicone caulk, it's a bit more flexible and I think less chance of coming loose than CA glue.  I like how you attached the 6 pin connector to the tender.  Mine are usually loose but your way looks like a neater option.
Quote from: Zephyrus52246 on July 07, 2025, 10:30:23 AMNice install.  I attach the speakers and other components with silicone caulk, it's a bit more flexible and I think less chance of coming loose than CA glue.  I like how you attached the 6 pin connector to the tender.  Mine are usually loose but your way looks like a neater option.
Thanks Jeff! I tried 3m sticky tape and it made removal a mess. The decoder is stuck on the side of the tender with scotch double sided tape. A lot less forgiving. The plug is stuck on with a black water based caulk and coming loose. Thanks for the tip! Yep, CA is kinda sketchy.
Philip,
Excellent job on the sound install and it sounds great.
Quote from: ACL1504 on July 07, 2025, 11:51:05 AMPhilip,
Thanks Tom!
Here was the proposed location for the decoder. I milled about 1/4 inch off the top but changed plans when the decoder length was longer than the recess.
A couple Wooten boiler shots. The rest is adding all the parts, aka buttoning up.
Quote from: friscomike on July 07, 2025, 07:44:28 AMHowdy Philip,
The sound is excellent. Nice work integrating it all into the tender.  Does that speaker fire downward through holes?
Here is the tender showing the cut out for the speaker and 6 holes for air.
Mike, The point of brush is almost touching the speaker.
Last one for now after a bit of assembly.
Tomorrow hopefully will finish......most likely not. 8)
Howdy Philip,
Thanks for the speaker photo and explanation.  The camel looks terrific, and I bet it runs well, too.
My current build is the Masonic Lodge and miscellaneous rolling stock .
Quote from: friscomike on July 09, 2025, 06:10:51 AMHowdy Philip,
No problem. It runs great and the sounds are really off the chart. It even has a headlight dimming function.
Outstanding installation Philip.
