2-6-0 Camelback with sound
Started by Philip, July 06, 2025, 06:52:09 PM
Philip,
The figures are starting to bring the locomotive to life.
Philip, you're doing some amazing work here.
Very impressive!
Thanks Ron and Rick!
I got lucky with the cab figure. After trimming several times he rests perfectly on the window sill. I was wanting him inside but he looks pretty natural hanging out.
Rick, I CA'ed the brass to the plastic with no gap followed by JB Weld tapering into the joint on both sides. Once dry I lightly sanded out the bevel to blend with the deck. Seems to have strength. Time will tell.
The cab figure is soaking in paint remover. I may get some time to finish today. Looking like rain and we need it!
Thanks for commenting !
Howdy Philip,
The engineer casting has a lot of nice detail in the face.  It should be a great-looking addition to the camelback.
My current build is the Masonic Lodge and miscellaneous rolling stock .
Thanks Mike, I worked on some figures including the guy above with kneadtite greenstuff. Works great for sculpting and patching and remains flexible. Takes forever to set. His hat was lost when removing all the paint.
Philip I'm impressed.  Your doing some really wonderful wor on this.
Quote from: Jerry on July 15, 2025, 09:39:30 AMPhilip I'm impressed.  Your doing some really wonderful wor on this.
Thanks but I would call it piddling my friend.
"Piddling" is a very important part of modeling and I haven't heard that term used in years. You're doing some masterful modeling here; have fun.
Owner & CEO of
Current Project: Hank's Machine Shop
A couple updated. Figures have cured. Maybe the paint will stick.
An old combine that is needing attention. The body was warped. Hoping the clamped area holds.
I also re-decked around the original weight. Planning some boxes and what not in the interior to obscure the unsightly post and unfinished area. I also removed the lighting kit. The floor needs a good block sanding as it crowns in the middle.
Thanks for looking!
What might work better next time would be some 1/2" aluminum angle epoxied to the floor....  I think you can get that stuff pretty cheaply at Home Depot or similar.
Philip, nice job of fixing up the crew and painting them.
New floor looks good too.
Howdy Philip,
Nice work on the figures.  The floor looks great.
Philip those figures look great!!
Nice job on the floor.
