CCK Doc Koontz Build
Looking good, Tom!  When you glue the chimneys, make sure they're between the windows.  A couple of those temp positions look like they overlap windows underneath.
John B
Great work, Tom.  Keep up the good work
Howdy Tom, your work is amazing.  It's always an inspiration.  Have fun, mike
This is looking better and better every post.
That was a great way to make parts for the support wires.
Looking good.
Tom, I thought it looked magnificent before, but now it looks even better.
Great job!
The building is looking better and better with each post.
Quote from: PRR Modeler on January 22, 2026, 06:06:48 PMTom, what you did today looks excellent.
Thank you Curt Butty.
Quote from: deemery on January 22, 2026, 06:09:35 PMLooking good, Tom!  When you glue the chimneys, make sure they're between the windows.  A couple of those temp positions look like they overlap windows underneath.
The photo you look at to come to that conclusion is at an angle. The two chimneys are between the read upper doors and the windows.
Quote from: John B on January 22, 2026, 06:59:25 PMGreat work, Tom.  Keep up the good work
Hey, very good to see you. Happy you came by for a visit. Thank you for the kind comment.
Quote from: friscomike on January 22, 2026, 09:49:38 PMHowdy Tom, your work is amazing.  It's always an inspiration.  Have fun, mike
Mike, Howdy,
Thank you sir for the generous compliment on the build, much appreciated.
Quote from: Pennman on January 23, 2026, 12:27:53 AMTom,
Looking good.
Rich,
Thanks very much for the comment and for stopping by.
Again, thank you.
Quote from: Rick on January 23, 2026, 06:35:00 AMTom, I thought it looked magnificent before, but now it looks even better.
Great job!
Rick,
Thank you also, I'm very pleased with how this one looks.
Quote from: elwoodblues on January 23, 2026, 10:14:19 AMTom,
Ron,
Your compliment is very much appreciated, thank you.
I stained all the strip wood I planned on using for the rear stairs.
I took a second look at the kit laser cut stair parts. The railing were very well done, so, I decided to use the kit railing.
This is a first for me as I've always scratch built my own railings.
I then glued the platform assembly to the building under the upper rear doors. I also made sure it was level.
I carefully made sure it was square tot he wall and let it dry overnight.
