CCK Doc Koontz Build
I used my stringers and cut the steps from the stained 2X6s. The stringers and stairs were glued in place and left to dry.
When dry, I touched up the sides of the stringer and steps.
I then glued on the stair railing.
I made two small angle brackets for the roof that will be positioned over the two doors.
Prior top gluing the roof in place, I added a few rafter tails. I also used the same Stoney Creek roof paper as I did for the lower sub assembly. Both roofs were weathered with pastel chalks.
The finial for the turret was the wrong shape on the bottom. I cut and flied the bottom so it fit as it should.
Also, I painted it with Floquil Brass and found the color to bright. I used Model Masters Jet Exhaust for the finial color.
You'll see the finial later in the thread.
Back in a few, Diet Pepsi time.
The finial and three chimneys were glued in place. I made a few final touches on the rear roofs and the patina on the upper main roof.
This completed the build.
Here are the final photos. Details were added as I went.
In a few days or possibly tomorrow, I'll add my thoughts and comments on the model.
What a perfect fit!!  And a beautiful build.
Quote from: Jerry on January 23, 2026, 03:31:47 PMWhat a perfect fit!!  And a beautiful build.
Thank you Jerry. I'm happy to have this one off the work bench. I can start the Winter Challenge now.
The way that fits in its location, you'd never know it was a kit!
Howdy Tom,
Wow, just Wow, what a beautiful structure.  I can't say anymore than that to describe the structure.  That said, just WOW.
This is simply outstanding modeling in every aspect Tom. I look forward to seeing it in person.
Outstanding structure build in all aspects.
Final coloring blends in beautifully.
