Thanks for the information, Dave.
I do wonder whether they would leave hairs behind as they ware.  I'm sure their will be multiple choices in the makeup section.
Quote from: Rick on February 04, 2026, 06:43:32 PMMark, the brick walls look fantastic.
Good technique on applying the mortar.
Thanks, Rick.
I like that well worn look.
Quote from: Larry C on February 05, 2026, 10:09:50 AMMark even though that looks like quite the process the end result is really worth it; great job and tutorial.
Thanks, Larry.
It is only really such a process because the building is so big.
Quote from: ACL1504 on February 05, 2026, 10:52:48 AMMark, Cheers,
Old, nasty and weathered bricks, love it!
Thanks, Tom.
Yes - nasty indeed!
Hi guys.
Thursday saw me starting work on my first Kahikatea tree (white pine) and so there was no progress to report.  Yesterday I was back on the tools for modelling Sunday.
I started off by glazing the 8 smaller windows for the elevator shaft.  These were then glued into position using medium CA.  As these were difficult to get into position, I pressed them in first and then added CA with a toothpick to the edges.  Just a drop in the four corners.
Photo 1 - The kit provided reasonably thin glazing material.  I cut this into strips slightly narrower then the window width.
Photo 2 - I then cut the pieces to height on my chopper.
Photo 3 - Here are some of the pieces.
Photo 4 - I applied six small drops of CA to the back of the windows on the edges.  Using a pair of tweezers I placed the piece of glazing in position and used a piece of stripwood to hold until the glue had set. After all the glazing was glued in position I gave the back of the windows a spray with Dullcote.  When this was dry I worked on cutting out the remaining floor sections to strengthen the kitbash and keep it square and true.  Once these were cut I marked their height on the back of the kitbash and cut and glued in stripwood.  I then glued the three floors and roof pieces into position using CA.  I applied glue to the edge of the floor/ roof that fit around the DPM kitbash and the start of the Atlas kitbash and held firmly in position until set.  I then applied lines of CA in sections of a few inches and held the floors/ roof pieces hard against the back of the kitbash and hard down on the stripwood until set, letting capillary action take the CA were it needed to to make a bond.  After the four pieces were glued in, I did a test fit in the model room.  I needed to enlarge the two cutouts in each floor piece for the vertical stripwood on the back of the Creamoata kitbash.  Another test fit showed a perfect fit.  The final job of the day was to add Aleenes tacky glue around all the windows and doors.  I also added this glue to the top and bottom of the floors and the bottom of the roof piece.
More soon, cheers, Mark.
Quote from: PRR Modeler on February 08, 2026, 03:36:01 PMGreat progress Mark. I dislike doing windows.
I think everyone dislikes doing windows  ;D   That's worse than doing shingles.
Thanks, Curt.
The windows are nearly all done - Just the DPM M. T. Arms Hotel to go.  Those windows are cast in so there is lots of fiddley painting to do.
Michael Hohn
Mark,
Very neat job on the windows.  Most find it hard to maintain focus and keep an edge doing such a fussy, repetitive task.
Quote from: Michael Hohn on February 09, 2026, 06:23:50 PMMark,
Thanks, Mike.
I didn't find this one too bad.  Access was good, which helped - apart from the eight windows in the elevator shaft.
Howdy Mark,
I think I would go stir crazy with that many windows. Excellent work adding glazing, and yes, if I only have two windows, I wouldn't like doing them.
Quote from: friscomike on February 11, 2026, 12:49:01 AMHowdy Mark,
Hi, Mike.
No crazier than usual here!  I actually think the DPM windows are the trickiest.  Cutting in in miniature can be challenging.  That is this afternoons modelling adventure.
Mark, Cheers,
Great job on the windows and all around on the build. Looking good to me.
Quote from: ACL1504 on February 12, 2026, 08:32:02 AMMark, Cheers,
Thanks, Tom.
I made some good progress on cutting in the cast windows in the DPM M. T. Arms Hotel kitbash yesterday.  It does take quite a bit of time, though.  I didn't quite get through it all.  I'm hoping to get the last ones finished off this afternoon.
