Mark, Cheers,
What a wonderful looking scene. The tall structures really make it believable. Fantastic job all the way sir.
Quote from: PRR Modeler on February 18, 2026, 07:15:52 AMIt sure looks like you have been busy Mark.
Thanks, Curt.
I try to get out to the model room no later than 11am on a Sunday and work through to 7pm.  It's usually my one big time slot of the week.  Projects like this take a fair bit of just looking and deciding which way is best to tackle the job.  If I just roll up my sleeves and get into it without first giving due consideration to the whole process I typically find myself half way through the job saying 'but what about that?'  Sometimes those 'that's' can be major problems!
Quote from: Jerry on February 18, 2026, 10:10:19 AMMark that is one great looking diorama.
Thanks, Jerry.
Cutting the trackwork off the front of the Creamoata diorama and the curved turnout out of the Innes aerated water diorama were moments!  I used a sharp hand saw and just tried to keep things plumb and cut through the 4 1/2" sandwich.  In the end things went pretty smoothly and no damage was caused.
Quote from: deemery on February 18, 2026, 10:50:43 AMMark gets more done in a week than I get done in a year!
Thanks, Dave.
I've told you a million times - do not exaggerate!  You seem to be getting through the work in good time at the moment.  The farm scene is coming on nicely.
Quote from: ACL1504 on February 18, 2026, 01:42:12 PMMark, Cheers,
Thank you for your kind words, Tom.
Lets not think about how close this location is to the alpine fault line!  Those brick multi-storied structures wont last!  There are several small towns on the West Coast built with half the town on one side of the fault line and the other half on the other side!
https://www.odt.co.nz/regions/west-coast/council-continues-urge-fault-line-properties-be-moved
Hi guys.
Photo 1 - I just thought I would add this photo to show the cubby holes I cut in the original baseboard to give access to the point motors to be installed above.  I cut these by drilling 10mm holes in the corners and using my jigsaw to cut the four straight lines.  Then the hoover to clean up the mess!
Great job of thinking ahead because the thing hardest to get to will break the first!
Quote from: Philip on February 20, 2026, 09:31:54 PMNice work! I really like that era!
Thanks, Philip.
Yes - the depression era also gives my town 65 years to have been built.  Plenty of time for a substantial town to have been built and some of it to be in a state of disrepair.  Our local town, Rolleston expanded from some 5000 residents in 2006 to over 34000 last year.  It has been interesting to see such quick expansion.
Quote from: PRR Modeler on February 21, 2026, 08:18:17 AMGreat job of thinking ahead because the thing hardest to get to will break the first!
Thanks, Curt.
Absolutely!
Mark,
Thanks for the overview of the overall scene, you made some huge progress in a very short time.  With the tall building your new build will fit right in seemlessly.
Quote from: elwoodblues on February 21, 2026, 12:44:50 PMMark,
Thanks, Ron.
Yes - it really needed to be done.  I have one more very tricky piece to do on the far end of the Innes aerated water manufacturer diorama.  I'm working up the courage to tackle that turnout!  But hopefully, when all done, there will be no issues with fit.
Hi guys.
Well, there was a bit too much wind at the dog shows on Saturday, so I spent my downtime reading.  Today, I got a bit of work done on the scratchbuild.
Photo 1 - I got the rest of the walls for the cannery measured out and cut to size.  There was a little bit of splicing to do as well.
Photo 2 - Here are the walls for the tower that will sit on the lower wharf.
Photo 3 - Once all the walls were cut I changed things up and scratchbuilt some vents for the walls.  I used evergreen clapboard and strip styrene to create the illusion of louvers.  I still have to add strip styrene to the three long skinny ones.
More soon, cheers, Mark.
Take a thin point permanent (black) marker and run it along the undersides of the scribes.  That adds shadow, and makes it look more like a vent:
(A firm hand helps, practice on some scrap first...)
