Howdy Mark,
The build is progressing well.  Nice work on cutting the different components.  The louvers are exceptional.
QuoteTake a thin point permanent (black) marker and run it along the undersides of the scribes.  That adds shadow, and makes it look more like a vent.
Thanks for the tip, Dave.
Quote from: friscomike on February 22, 2026, 06:12:31 PMHowdy Mark,
Thanks, Mike.
I was finding them rather fiddly to build so I though I'd give my ptastistruct glue that I found on the shelf a go.  It just melted the plastic and quickly ruined my next louver, so back to fiddly and medium CA!
Quote from: Michael Hohn on February 24, 2026, 03:07:27 PMCool looking building, Mark.
Thanks, Michael.
It's been fun designing this scene.  I was back working on the trackbed surrounding the diorama today.  I should be back working on the structures this Sunday.
Quote from: Philip on February 25, 2026, 09:50:56 AMLooking great! One big bite for a challenge!  ;D
Thanks, Philip.
I always take big bites.  I just have to find time to chew for long enough!
Quote from: GPdemayo on February 25, 2026, 11:59:07 AMVery impressive scene Mark, looking good..... 8)
Thanks, Greg.
I'm looking forward to working on the scratchbuilt section.  I also have some scratchbuilding in the form of aerial walkovers and the large stack that will be fun.
Mark,
Don't know how I missed your last update but the louvers look great.
Quote from: Larry C on February 26, 2026, 09:35:48 AMMark that's coming along nicely.
Thanks, Larry.
We have a modelling meet here the first weekend in March.  I'm hoping to make a big chunk of progress then.
Quote from: elwoodblues on February 26, 2026, 11:22:09 AMMark,
Thanks, Ron.
These is always lots to look at on the forum - sometimes things are easy to miss.  Thanks for the compliment!  We have a bit of a garden tour tomorrow so will be busy weeding today.  Hopefully back to some modelling on Sunday.
Hi guys.
We had another nice weekend modelling in my garage last weekend.  Of course, I was hosting, so there was a fair bit of preparing lunches and making sure everyone had what they needed.  Various requests came up during the weekend for items that inevitably got left at home, and I think I was able to fulfill them all.
Photo 1 - Shows the top section to the Walther's Front Street Building.
Photo 2 - For the long section behind the tower I needed to cut the walls and roof pieces down.  You can also see at left the scratchbuilt wall I fabricated to keep the end square and true.
Photo 3 - I assembled the two square towers.  The roof pieces were tricky to find, as they were done in Clear plastic and packaged with the window glazing.  I didn't look there for quite some time! I then measured and cut down the window walls and the roof sections.  I made a back wall to sit against the 5th story behind and to keep things square and true (shown in photo 2).  I glued together using medium CA, gave a wash with dishwashing detergent and warm water and when dry, sprayed with rattle can grey primer.  The next day I sprayed with rattle can moss green - the same colour as the windows.
Photo 4 - Shows the base for the towers (you can see the raised mounting pieces over which the rooftop towers and cupola sit).  You can see I have attached the main roof.  I made up trusses to keep the roof true and add strength.  There was a problem with the longer roof sagging so I glued in a styrene strut widthways underneath the sub roof to push the sag up.  This helped quite a bit, but I couldn't get things quite perfect.  I will address this issue in a later step.
More soon, cheers, Mark.
