2025-2026 Winter Challenge - AMB Interlocking Tower
Started by ACL1504, January 23, 2026, 04:38:06 PM
Tom, stairs look good.
Glad the levers were removed easily.
have fun re-doing the interior.
Tom nice job on the stairs.  And really a great job on those levers without breaking them.
Vietnam Seabee
Tom...always informative to see how you work your way out of sn 'issue'
terry
Quote from: deemery on February 08, 2026, 04:40:58 PMIt's always interesting to see "rework".  I think the result will be worth the hassle, there's a lot of window surface to let someone see into the tower.
I agree and this one I knew would turn out fine. I applied little glue to hold the lever base.
Quote from: Rick on February 09, 2026, 08:35:48 AMTom, stairs look good.
Rick,
Thank you. The lever base came out broken but the lever pad, no damage.
Quote from: Jerry on February 09, 2026, 10:35:01 AMTom nice job on the stairs.  And really a great job on those levers without breaking them.
Jerry,
Thank you. If the levers were glued to the floor, it possibly could have turned out badly.
Quote from: Vietnam Seabee on February 09, 2026, 10:39:27 AMTom...always informative to see how you work your way out of sn 'issue'
terry
Terry,
Thanks Butty, much appreciated.
BTW, I've been reading the instruction manual on the RSM Horwood Brothers kit.
When I finally got the lever base out of the tower, I noticed some of the stain was removed with the glue. Not a big deal though.
The tower floor was damp,  so I used a paper towel and stuffed it into the tower for 30 minutes to absorb the moisture out of the floor. I believe this helped to not have a warped floor.
I didn't glue the new lever base in place but you can see I now have room for a desk. And, the light spot is no longer visible.
Done for today.
