Michael Hohn
Quote from: Larry C on February 26, 2026, 09:29:21 AMMike the building is looking soooo good! Glad to see I'm not the only one that uses clothespins in modeling.
Larry,
Thank you!
Since we had the outdoor clotheslines removed to make room for a garage, modeling is the only use we have for clothespins.
Michael Hohn
Parts of the feed mill are metal clad.  From the photos, the cladding was added over the original clapboard siding.  Both wood and metal look beat up.
I decided to use "corrugated iron" material from Mine Mount, a paper product I find superior to actual metal.  It comes in long strips, already in a galvanized iron finish, although I will be painting it.
The first step was to cut out pieces 8 scale feet by 4.5 scale feet, a little wide but those proportions will fit the building better.
I stuck them to a piece of cardboard and painted them white;
I also gave them a light dusting with cream and dark brown powder to take away the new white look:
I cut some to a shorter length, weathered them some more with dark brown acrylic and powder to look like old rust and wear, and glued them on the building with canopy glue, which I find good for joining dissimilar materials. The results:
Almost ready for the roof.
Mike love the look of the weathered iron siding.
Michael Hohn
Michael Hohn
Quote from: PRR Modeler on February 27, 2026, 07:09:54 AMThat is a great weathered color Mike.
Thank you, Curt.  I learned some of how to do it on a forum like this.
Mike, great job on the corrugated siding, can't tell it's a paper product.  Thanks for showing us how you did it.
Michael Hohn
Ron,
Thank you.
I remember being skeptical about using a paper product but seeing good results when others used it and having experienced problems with metal, I can say that I like it.
Michael Hohn
Hi folks,
It's been almost a week since my last update.  The weekend was spent in Pittsburgh with my wife at a blues dance event: workshops and live bands.  No time for modeling.
Now that I'm back, I've been busy adding roofs to the mill. My procedure is to add some cross bracing to stiffen and attach the 1/32" plywood I use.  Here are a couple of in-progress photos:
I use scale 12 by 12" lumber for the bracing.  Another section of roof glued in place:
The bracing for the longest roof sections:
Meanwhile, I've started work on the diorama base.  More on that later.
That strikes me as a very realistic level of weathering: tired, but still a going concern. One good year or a few new customers and they could afford to scrape and repaint...
Michael Hohn
Quote from: jbvb on March 05, 2026, 02:17:45 PMThat strikes me as a very realistic level of weathering: tired, but still a going concern. One good year or a few new customers and they could afford to scrape and repaint...
Thank you.  What you wrote is what I was aiming for.  I intend it to be part of operations on my layout.
Michael Hohn
