Michael Hohn
Hi James,
In the past when I've used similar brushes they seemed to lose bristles.  Perhaps they were a cheaper version.
Mike looks like you've achieved what you're going after; well done.
Michael Hohn
Quote from: Larry C on February 08, 2026, 07:49:50 AMMike looks like you've achieved what you're going after; well done.
Thanks, Larry.
Interesting use for that type of brush.  Nice effect on the walls.
Michael Hohn
Jeff and Mike,
Thank you.  It turned out as I hoped.
Mike,
When I sat the picture with the huge brush I thought it was overkill, but seeing the final result it was the right choice as you nailed the effect you were trying to achieve.
Michael Hohn
Quote from: elwoodblues on February 08, 2026, 10:42:54 AMMike,
Ron,
You can be sure that I tested it on a scratch piece of siding.
Michael Hohn
Michael Hohn
Michael Hohn
I've been adding trim and working on the doors.
The trim comprises scale 6 by 6 stripwood.  Once the walls are assembled, each side butts up against the 6 by 6 corner pieces.
I made the doors by cutting out stripwood:
staining the boards:
and dry brushing the white paint with a small brush:
Here's the result:
I used scale 3 by 8" planks for the sliding doors and 2 by 4" planks for the man door.
My first attempt did not go well.  I stained the stripwood, cut them out, glued them side by side, and drybrushed the white.  I could not see the individual boards.  My solution was to cut the boards first, sand the edges to round them off a little (not too much), paint each, and them assemble into a door.
