 8)  In the cabinet biz, we called those fillers long ago!
Nice work!
Michael Hohn
The plot thickens. Your narrative is getting ever more interesting.
Howdy Tom,
The trim work is exceptional.  Good luck with the power board location. I'd be looking to locate it behind a faux wall on the back of the structure.
Ensign
Hi Tom, I have used a diagram from my Horwoods kit to show you how I think you could work with 2 LED distribution boards instead of just one.
You can easily daisy chain the 2 distribution boards together and still only use the one power supply to power both.
The conecting wires for the distribution boards can be run under your layout/structures.
All of the other magnet wires for the LED's can be run internally within each structure.
Also give you more space on the boards to add more LED's to light up the interiors if you choose to do so.
So the red lines shown on the diagram indicate interior walls that I added to my Horwoods, and the green boxes represent the LED distribution boards.
The distribution boards will be hidden behind the added interior walls, and easier to hook up from above when the time comes to do that part.
I will be more than happy to answer any other questions that you might have in building this wonderful kit.
Greg
Quote from: deemery on April 04, 2026, 08:18:42 PMI was thinking reading this that a line cut through the concrete between the two buildings, then covered by asphalt, would be prototypical.  That could be a plumbing repair, drains, etc.  But I see you have another solution in mind.
That is a good idea and I'm not sure what I'll do here. However, I did make a note of your suggestion.
Quote from: Rick on April 05, 2026, 07:49:30 AMGreat tip on cutting those angles.
Hope I can remember it if I ever need to do the same.
Rick,
Thanks, I've used this method to cut angles on to many models to count.
I'm sure you'll remember when the time comes.
Quote from: Vietnam Seabee on April 05, 2026, 07:53:17 AMReally a learning experience following along with your builds
terry
Terry,
Thanks, I learn as I go as well.  ;D
Quote from: jbvb on April 05, 2026, 08:51:54 AMGood progress, Tom. Parts of your narrative remind me of my working years: Fixing bugs in someone else's software...
James,
Thank you. Your comments reminded me of some of my work years as well. As the Special Operations Commander assigned to the Orlando International Airport, I wore many hats. One of the things the Captain asked me to do was to respond in writing, for the Mayor's signature, complaints that came in on officers.
These officers didn't work for me but I was tasked with writing the response. I asked the Captain, "Why am I handling this complaint and not the officer's Lieutenant?" His response, "The Mayor likes the way you answer and address the compliant."
 So, if you are good at your job, you get to fix the bugs/complaints others don't seem to be able to.
Quote from: ACL1504 on April 13, 2026, 02:29:58 PM
James,
Summary of Tom's story, "The reward for good work is ...  more work."
Quote from: Jerry on April 05, 2026, 08:59:09 AMTom great idea with cutting the trim.  And doing the lighting.
Jerry,
Thanks my friend for stopping by and posting your thoughts.
Quote from: deemery on April 13, 2026, 02:30:49 PM
James,
Exactly right Dave, spot on for sure.
Quote from: elwoodblues on April 05, 2026, 08:59:22 AMTom, Nice work on the trim.
Seeing as you plan to put the light board between the 2 buildings, I'm assuming you have another solution besides the alley.
Ron,
Thank you. The light board will not be located there after all. Please refer to the post from Greg and my response.
Quote from: Philip on April 05, 2026, 08:37:03 PM8)  In the cabinet biz, we called those fillers long ago!
Nice work!
Philip,
Thank you. Yes, fillers. I've done my share of using fillers on models also.
