After checking all the corners, I went back to review the wall locations in how they are glued together.
I discovered the second issue with what I did wrong.
The diagram in the next photo shows the other self inflected wound.
Clearly it shows Wall T to be glued to the inside of Wall S. The darker lines are the bracing.
I glued Wall T to the outside of Wall S. This was why the showroom didn't sit correctly. A minor mistake that was magnified down the road.
Ungluing or cutting the walls apart clearly wasn't possible. Even though, I've been successful in doing this on other models. With this kit, the two showroom walls are to fragile for me to even attempt doing that.
My solution, fix #2, was to create a small alley between the middle building and the showroom.
By doing this, I was able to square up the front with the sidewalks.
Done for today and probably the next few days as well!   ;D
Tom that's some creating thinking on your part and since this IS your empire you can make whatever changes that "floats your boat."
Tom very well done.  And a great idea with the alleyway.
Wow Tom, that station is huge and looks so good.  ~mike
Wow...what a beautiful kit...I'm just catching up and looking forward to your continued build. It'll look great on the layout.
craftsmankits
Tom.
Nice solution to your problem. Your separation of the two structures makes perfect sense.  Still following along, enjoying the journey.
Great solution to the self inflicted wound.  I forgot how big that building was.
Yannis
this pans out to be a really good looking structure!
Thanks Tom on the 5" distance from the mainline piece of info. It will come handy in my scene compositions.
Quote from: Larry C on March 23, 2026, 05:19:34 PMTom that's some creating thinking on your part and since this IS your empire you can make whatever changes that "floats your boat."
Larry,
Thank you and yes, it is my empire. When Pam asks, "What are your plans for today?", my response is "Building my empire!".
Quote from: Jerry on March 24, 2026, 09:56:04 AMTom very well done.  And a great idea with the alleyway.
Jerry,
Thanks, much appreciated. However, I may need to change the alleyway idea.
More later on this.
Quote from: friscomike on March 26, 2026, 03:46:27 PMWow Tom, that station is huge and looks so good.  ~mike
Mike, Howdy,
It is a large kit and may be just a bit larger when finished.
Quote from: cuse on March 27, 2026, 07:50:15 AMWow...what a beautiful kit...I'm just catching up and looking forward to your continued build. It'll look great on the layout.
This has been a fun build but with minor issues. I agree, it will look wonderful on the layout.
Quote from: craftsmankits on March 28, 2026, 12:00:34 PMTom.
Mark,
Thank you. I appreciate you following along on the journey.
