I used 8X8s to make a floor base frame. I made the floor out of thin cardboard and painted it a tan color. When the paint was dry, I sprayed it with a gloss finish.
I then glued it inside the small office on the floor frame. This office will have the door open.
I used a 2ply cardboard for the the service bay. I needed a little more side edge to glue it in place. I used HO scale 2X4s and glued them to the top of the cardboard flush with the sides.
I also sanded down the front edge of the cardboard to remove the square edge.
To match the red, I painted them with Floquil Signal Red. I pained t he floor with Folkart Cool Concrete.
I'll use pastels and A&I to weather the floor later in the build.
When the bay floor is installed, you can't see the scale 2X4s on the sides and the floor is a little darker.
For the office on the left, I installed a wooden oak floor. I used the same style of floor bracing as I did with the office on the right.
This middle building is now ready for stucco.
Done for today.
Tom, it couldn't have been easy make that doorway bigger with the walls put together.
Floors look good.
I'm always floored by your creativity.
Great job Tom.  Like I've said before you can learn a lot about modeling watching you do one of these kits!!
Nice workaround on this kit, Tom.
It appears you have this under control.
Howdy Tom,
The details you are adding to the interior are top notch.  Horwood is progressing nicely.  It's fun to watch your build.
Quote from: Rick on May 06, 2026, 06:48:49 PMTom, it couldn't have been easy make that doorway bigger with the walls put together.
Floors look good.
Rick,
Thanks and no, making the door larger was a bit tricksie.
Stay tuned, maybe I can get you floored once more.
Quote from: Jerry on May 07, 2026, 05:23:14 PMGreat job Tom.  Like I've said before you can learn a lot about modeling watching you do one of these kits!!
Jerry,
Thanks very much. Always happy to share any small knowledge I have.
Quote from: Pennman on May 07, 2026, 07:43:55 PMNice workaround on this kit, Tom.
Rich,
Good to see you stop by for a look see. I've got a handle on this for at the moment.
Quote from: friscomike on May 08, 2026, 08:10:19 AMHowdy Tom,
Mike, Howdy,
I'm happy you are having fun following along. It has been a fun build for me as well. And, thank you.
Quote from: PRR Modeler on May 08, 2026, 04:25:53 PMLet the stucco times roll! ;D
It won't be long now until the stucco starts flying around and hopefully on the walls.  8)
