O'Neils Mercantile & Repair
Jerry thank you so much.
Curt thanks. Not sure though how a HO scale one would go together.
Philip thanks; thought I'd go with the green for a change.
Rick thank you.
Howdy, Larry. The lathe looks fantastic.  The colors, shading, and assembly are first class.  Have fun, mike
Mike thank you so much for the nice comment.
Quote from: Larry C on May 28, 2026, 06:07:56 PMPhilip thanks; thought I'd go with the green for a change.
You can't go wrong with that color!  ;D
Quote from: Philip on May 30, 2026, 08:33:58 AMYou can't go wrong with that color!  ;D
Ya, I thought it would add a different color palette with all the brown tones in the build.
craftsmankits
Beautiful work on that lathe.  It's my first time visiting this thread, now I've got to page one.  Mark
Mark thank you for your nice comment. Glad you stopped by and hope you enjoy the thread.
Moving along:
Decided to keep the lathe in the Shed so I placed it in the large doorway leaving room on the far end for the LP's to move stuff from behind the building. Being the lathe is a 3D print the belt will not physically go under the cone pulley. Instead you have to glue it in such a way it "looks" like it is. Figured I'd better do that before I glued the lathe in place. Also added a few more details like the box of junk on top of the shelving unit and also a hand cart. I glued the disconnect to the tracks as well.
Here's a better view of the handcart with a wood water barrel on the front plate. As you can see there is a good amount of room between the end of the lathe and the doorway.
The area between the Mercantile and the Repair Shed looked rather stark so I added a few details; 5 to exact of parts I already had on hand. All of them were either painted with craft paints, chalks and clear alcohol and/ or a combination of both.
In the first photo is a seat on a wooden box with a "spittoon" on the side. I added a few "tabacky stains" beside it on the floor showing someone had a bad aim.Also added a propane tank on the corner of the building.
The second photo shows the chair in greater detail. Basically a wooden crate with an old tractor seat attached with a makeshift back rest. In the foreground is a wooden barrel with some parts showing at the top. The one thing I didn't want to do is "over detail" this area but add just enough to help fill in the gap while adding to the diorama story.
Here's a "top down" view of the back porch just to show there's still plenty of room for people to work in the Shed. Thanks for stopping by for a gander and for all your great comments and/or suggestion; they are appreciated so stay tuned.
Curt thank you; it's coming along.
 It gets better and better!  ;D
