O'Neils Mercantile & Repair
Philip, Rick, and Jerry thanks guys for the nice compliments.
kyle creel
Hey man  :o ..that's some mighty fine work, Larry C*., I'm trying to get caught up .....ya'll have been busy :o  :o  :o ...WOW......
KYLE CREEL
DORRE & GAPHETID Ry Co.
Thanks Kyle; working at it a little bit at a time.
Probably one of the things that's the most difficult for me is making stairs going from a second story to ground level. I've only made simple stairs one other time but this time I decided to go for broke.
Started with stringers from Wiseman since they are white metal; last time I used plastic ones and didn't like the look and they were a bear to work with. After making the porch for the second story I then made a landing so the direction of the stairs could be changed. The fun part was figuring out where the landing had to go in relation to the top set of stairs and still having the second set go from the landing to ground level.
Both the porch and landing are made from 2x10s. The support legs from 4x4's, the bracing from 1x4's, and the stair treads from 1x6's. All the wood was given my usual treatment of graining and coloring. To my delight the set of stairs didn't turn out too bad. After I have this side area detailed then I will go ahead and add railings so nothing gets broken.
To start with the detailing I made a bench top from 4x10's for a beefy look and a length of 1x6 for the drawer front adding a shortened track nail for the pull. This was set on 2 50 gal. drums then individual details added to the bench. To hide the open landing side I found a small cabinet with items on the shelves with a few boxes of junk on the end. Most everything was colored with various colored chalks and clear alcohol. This won't be glued in place until the railings are installed.
Next I think I'm going to continue on with building 2 or 3 more small structures for the diorama. I want everything in place before I even consider adding scenery material. I do however need to start working on the knoll that will go behind the Repair Shed more for spacing than anything else.  I'm trying to think two or three steps ahead on this build so I don't end up tripping myself up.Thanks for stopping by and for all your great comments and/or suggestions they are appreciated so stay tuned.
Larry great job!  Are you doing a railing?
Just a little dirt on the treads were the LP walk and your perfect.
Looks great Larry. I agree with Jerry's suggestions. I like how you used the details in the photo.
Stairs look very good.
I also would add railings.
Railings were always the hardest of stairs for me.
 8) Looks pretty dang good Larry!
Those two structures look good together.
Thanks Jerry and yes railings will be added later after that area is completed. Thanks for the dirt on the tread suggestion.
Curt thank you the details are the fun part.
Rick thank you so much. Railings are tricky and tend to break if accidentally hit.
Philip thanks, a little bit at a time.
Dave thank you; this is a different type of diorama for me.
Howdy Larry, the diorama is coming along nicely.  The details fit the scene well.  It's fun watching you put this together.  Have fun, mike
Mike thank you and for your input; it's appreciated.
Larry,
Finally, I'm getting caught up on all the threads.
The shop wood coloring and weathering look spot on to me. Great detail and I love the green lathe, very well done. The back story for the disconnect makes sense to me.
Tom thank you for the nice compliments; they are appreciated.
Made a small simple shed; nothing fancy but thought it would add some more detail to the diorama. It measures 10 ft.x8ft. with it being 8 ft. in the front and 7 ft. in the back to get a sloped shed style roof.The frame is made from 6x6's using my own design on 1/4 inch graph paper. The siding is made from 1x6's since they are narrower and fits the scale of the shed better. The closed door is made from 1x6's glued onto 110# paper and the frame is 1x4's as well as the molding around the door. The strap hinges are made from a thin plastic strip I hand on hand while the door knob is a cut rail nail. Everything was grained, colored with chalks then given a liberal coat of A&I. Added a little rust to the door knob, hinges, and the lucky horseshoe over the door. I also added a couple of signs on the shed.
The 2 photos shows the sides and back of the shed.
Wanted some variety on the different roofs for the diorama so I decided, since the roof is small, I'd go with a shingled roof. The shingles are made from 1x10 strips, colored with raw umber and clear alcohol then given a liberal coat of A&I. When dry the strips were cut into 2 foot shingles then glued to a piece of cardboard varying the lengths showing as I progressed. Lapped each row 6 inches onto the one below it. Even though this was a small roof I still used 84 individual cut shingles to cover it.
Next I think I'll start adding more details around the Mercantile as well as tackling the railings. Also need to order and paint a bunch of LP's at least for the Mercantile and back porch area. Thanks for stopping by and for all your encouragement; it really does help so stay tuned.
