O'Neils Mercantile & Repair
The figures look great Larry.  Wonderful job.
That is one hell of a shelf of dioramas.
I think your right a bigger shelf might be in your future!!
Jerry thank you for your kind words. Hopefully I can get by with what shelves I have for awhile.
These trees are Woodland Scenics fresh out of the container. Not too bad looking except for the "plastic look of the trunks" on the left. The tree on the right had the trunk modified. Used a base color of brown and clear alcohol; when dry a dry brushing of a light brown followed by grey. Also I thought the foliage was way too much so I thinned out the one on the right then bent the branches down a little to look more natural.
Here are the 2 trees redone and glued in place minus the bases from the first photo. They had a pin on the bottom which allowed them to be glued in place. After they dried then I added the scenery material. Also added a few details on the knoll but kept it sparse so as not to look too "junked up".
Here's the one end looking down the back of the Repair Shed. Used lots of grass and weeds with not as much dirt. I actually was able to get the area blended in to look like a solid knoll.
Here's a closeup of some of the details. Two old tires with weeds growing out of the middle, part of the old steam engine, an old bent rusty barrel, and part of an old dynamo.
This is looking down the other end of the back of the Repair Shed. I'm quite pleased the way this turned out and also helps eliminate some of the flatness of the diorama. Next I want to add a few details to the front side of the Shed including a LP inside. That's about it for now and thanks to all who stop by for a look-see. Much more to come so stay tuned.
Very nice Larry, the knoll looks real.
Curt thank you; that was my goal.
You made some righteous trees there Larry!  8)
Dynamo Modeling! ;) Pickers Heaven!
Philip thank you. Actually the trees are from Woodland Scenics I just enhanced them somewhat.
robert goslin
Nice work on those ready made trees Larry.  And just a right amount of items scattered around them.
Regards  Rob
Melbourne,  Australia
Larry great job on taking the trees and making them a lot better.
Details look well placed.
Rob and Jerry thank you so much. When I ordered the trees I knew they'd need some enhancements
and certainly better than I can make from scratch.
The entire back of the diorama has scenery; this is what it looks like front the front. Added some grass patches, weeds, bushes, and of course the refurbished tree.
Looking from the side down behind the Repair Shed and I also added a boulder for something different.
This is the left end of the back.
And finally the entire back of the diorama. The nice thing about detailing all four sides I have the option to position it so I can look at each side then when tired of it just change position. Next will be detailing the cutoff saw shed with some sawdust and have a few cut planks resting against the end roller; I may or may not add a LP to the shed. Also I'll continue with the scenery material going forward. Thanks for stopping by and for all your great comments and/or suggestions so stay tuned.
Larry everything looks outstanding. I like all the belts and equipment also.
Curt thank you for your nice compliment.
Nice that you can view all the sides.
it's a great looking diorama.
