Blacksmith Shop
That is a really nice looking able.  Very neatly done.
Quote from: Larry C on June 19, 2026, 07:16:59 AMExcellent work on the gable end; it doesn't get any better than that. By the looks of your tape the amount of trusses looks about right; to me at least. Never understood why some modelers go so nuts on the number of trusses.
Thanks Larry! Take a look at the original truss design from Stoney Creek Designs #21.  :o Prototypical modeling seems to be falling on the way side as it increases labor, costs, and materials?
Quote from: Rick on June 19, 2026, 08:09:34 AMPhilip, good catch on the oops and fixing it.
Gable end looks good.
Thanks Rick! Indeed an OS moment!
Howdy Philip,
The framework is progressing nicely.  Good job.
Quote from: friscomike on June 19, 2026, 10:10:55 AMHowdy Philip,
Thanks Mike!
Nice looking truss work.
Every model has some stuff it reflects, and some stuff it removes.  Interior framing is usually on the "if it can't be seen, it's not worth doing" side of practical modeling.  But that's what makes a model that does interior framing so special.
Quote from: PRR Modeler on June 19, 2026, 10:34:19 AMNice looking truss work.
It is pretty amazing what Roger designed. 8)
Quote from: deemery on June 19, 2026, 10:35:49 AMEvery model has some stuff it reflects, and some stuff it removes.  Interior framing is usually on the "if it can't be seen, it's not worth doing" side of practical modeling.  But that's what makes a model that does interior framing so special.
Indeed Dave. I stick with the 2 foot rule the majority of the time. Now a front and center model would be different, like your shop.
labdad
Phillip,
Excellent.
Wondering if you used "spacers" to keep things tight & square.
I always cut parts in groups if they're the same size/length.
Even with my furniture.
MJinTN
Quote from: labdad on June 19, 2026, 09:04:15 PMPhillip,
Excellent.
MJinTN
Back when I was production trimming I would gang cut window jamb extensions with pony clamp/stops set up. Same with the 45's except one at a time with a stop on the table. We would do chair rail and bed molding and I would use a magic block for the layout. 2" off the corner walls and 4" in between. All in the math. Same with foyer columns. Saved time. We could do a two story house in a day, including a prefabbed handrail. The expensive houses with the real deal trim would take 5 days.
No gauge blocks. I just work slow and get things close enough. All the horizontal nailers/fire breaks were slightly.
different length.
I'm using a homemade miter box because of all the odd angles. The roof is almost 9/12. It took several tries to get that angle...not sure what it even is. I wish I could birds mouth the rafters but the boards are so tiny.
Thanks man!
To me the # of rafters shown is crazy unless you're "a rivet counter" and want to make the model prototypical. I'm more of a "practical modeler" where if it seems reasonable and looks good I'm going with it; but that's just me.
Quote from: Larry C on June 20, 2026, 07:10:36 AMTo me the # of rafters shown is crazy unless you're "a rivet counter" and want to make the model prototypical. I'm more of a "practical modeler" where if it seems reasonable and looks good I'm going with it; but that's just me.
The original model was unpractical. The rafters are spaced 12" apart. Hence 22 plus the 2 outrigger ends.  :o  Thanks for chiming in Larry. Good enough crowd ;D
My late brother the carpenter hated working on roofs.  It's either too hot or too cold, always dangerous and back-breaking.  One advantage of models is that it's much easier to work on the roofs than on the prototype...
Quote from: deemery on June 20, 2026, 09:00:51 AMMy late brother the carpenter hated working on roofs.  It's either too hot or too cold, always dangerous and back-breaking.  One advantage of models is that it's much easier to work on the roofs than on the prototype...
I framed for a few years. Feast or famine. So true Dave.
Philip,
As others before me have said, very nice work on the walls, and roof structure.
I think Roger may have used too many trusses too, but am wondering with 22, he might
have considered that many due to people lifting off the roof to see the interior details.
I think at least eight with the gable ends included would work just fine. I also believe whatever
number you decide to use would be sufficient for stability.
Quote from: Pennman on June 20, 2026, 11:11:00 PMPhilip,
Seems plausibly. Maybe tornado proof?  ;D
I'm going with 6 total to hold it together plus the 2 faux outriggers on each end.
