Advertise Here - SUPPORT TMF
Author Topic: Shadowlands and Tellynott  (Read 23913 times)
  • T-Shirt - FORUM SPONSOR
  • Modeler's Hero 500+ Posts
    • View Profile
Re: Shadowlands and Tellynott
« Reply #270 on: May 12, 2021, 05:28:22 PM »
Hey Mark:
Wow!!!!! That is really starting to look just great. Can’t wait to see more.
    • View Profile
« Reply #271 on: May 22, 2021, 06:32:37 PM »
Quote
Great modeling, it really looks nice.
Thanks, John.  I think its the first time I've added an extension downwards.
    • View Profile
« Reply #272 on: May 22, 2021, 06:35:20 PM »
Quote
Wonderful! Wonderful modeling once again!!
Thanks, Jerry!
I'm getting better at these scratchbuilt doors.  I've already run out of 6x1" and 3x1" lumber.  Another order to Northeastern scale lumber soon...
    • View Profile
« Reply #273 on: May 22, 2021, 06:36:13 PM »
Quote
Thanks, Karl.
More to come soon...
    • View Profile
« Reply #274 on: May 22, 2021, 07:12:38 PM »
Hi guys.
These wharfs sure swallow up the timber!
I bought Campbell's Norms fishing pier off trade me a while ago for a pretty reasonable price - with the intention of repurposing it for the wharf for my sailmakers, boat builders and ships chandlers.  To start with I studied the plans closely and using spans and structural elements as a guide, drew up my own plan for my wharf.  I mocked up the wharf and structure atop with boats docked at this wharf and the wharf opposite.  I decided that two boats in this small harbour looked too congested, so decided to add a small floating dock to the side of the Ships chandlers wharf in place of a second boat.  I now have too many boats!  I also tried moving the structure and wharf back by half an inch to make room for a slightly larger boat in front, as well as trying adding a quarter inch in height.  Both these adjustments, although small, changed the visual dynamic of the scene and so the positioning and height will remain as they are.
I cut a piece of 2mm MDF to the shape of half the inlet.  It would have been good to do the whole inlet in one go, but I wanted to keep the size of the diorama manageable.  I cut the 12 degree cut with a drop saw, as well as cutting a second piece for the other diorama base - so I should get a good, tight join.  I painted the base with burnt umber, oxide green and smeared in unbleached titanium.  I'm not sure if I'm happy with my colour yet.  I taped the plan on top of the MDF and marked the center of all the piles using a compass.  I then removed the plan and drilled the pile holes with a 5mm drill bit.  I figured this would be the best way of insuring the piles were installed plumb.
A large amount of scale lumber - piles, bearers, joists, decking and braces, as well as timber for the small upper decks and stairway were weathered and stained.  Weathering was done with a fine razor saw and 180 grit sandpaper.  It took four baths in my leather dye and alcohol bath to stain it all.  This did give slightly different strengths due to the different bath durations.  To allow for this I stained a small amount of all the different sizes of timber in each bath.  The Campbell kit provides sheets of decking, which I will use under the structures.  I managed to get together enough stripwood from other sources to do the visible deck in individual boards.  I used decking the same thickness as the sheet decking.  I may pull some of the stripwood through a paper towel soaked in titan buff for some variation.
Photo 1 - shows my plan.  I spent ages getting my spacings right.  I have also designed the subfloor so that I can run the decking in two directions joining with a stagger pattern at the 45.
Photo 2 - shows the 2mm MDF with the holes drilled for the piles.
Photo 3 - shows the four bath loads of timber.
Photo 4 - is a close up showing the razor saw grain in the piles.
More soon, cheers, Mark.
    • View Profile
« Reply #275 on: May 23, 2021, 07:33:54 AM »
Mark,
The wharf is really going to be a great focal point. I like how you plan your dioramas so they are manageable for give you the best possible viewing.
Looking forward to more on this.
Cheers, Tom
    • View Profile
« Reply #276 on: May 23, 2021, 10:14:35 AM »
Hey Mark:
You are quite welcome.
    • View Profile
« Reply #277 on: May 24, 2021, 07:36:51 AM »
Impressive dock plan.....looking forward to seeing your build Mark.  :)
    • View Profile
« Reply #278 on: May 24, 2021, 08:58:46 AM »
Looks like a great project. I love projects that require lots of strip wood.
    • View Profile
« Reply #279 on: May 25, 2021, 12:06:24 AM »
Quote
Thanks, Tom.
Yes.  Again, there is a lot of work in this one - but also a lot of fun.  It was funny how such slight changes to the positioning and height of the wharf and structure seemed to have such a big impact.  I was really keen to make room for another boat - but not at the sacrifice of what looked right.  I couldn't imagine building a structure and then trying to fit it on the layout.  I've done it once and it took me 7 years to place it!
    • View Profile
« Reply #280 on: May 25, 2021, 12:08:20 AM »
Quote
Thanks, Gregory.
I've started putting together the bents...
Cheers, Mark
    • View Profile
« Reply #281 on: May 25, 2021, 12:16:07 AM »
Quote
Thanks, John.
Yes - I feel another Northeastern scale lumber order coming on.  Shipping times are rather random at present.  I was talking to a chap who waited 9 months for an order.  Ordered last May, arrived this February.  He  tracked it and it bounced all over the world.  Even arrived in Auckland, NZ, then went to Sydney before coming to Christchurch!  I'm at 5 weeks for my replacement Scale structures wall - so guess I can't complain yet...
    • View Profile
« Reply #282 on: May 25, 2021, 05:31:54 PM »
One of Campbells finest plans.  I'm sure positively you'll make this into a masterpiece when done.
    • View Profile
« Reply #283 on: May 29, 2021, 06:51:45 PM »
Quote
Thanks very much, Jerry.
And I'll have fun trying!
    • View Profile
« Reply #284 on: May 29, 2021, 07:07:22 PM »
Hi guys.
I thought I'd give a quick update this rainy Sunday morning.  We've had 80mm (3 1/4") since 3pm yesterday and there is still another 100mm (4") to come.  That's a lot of rain for Canterbury.  We have a red weather alert, and rivers will no doubt burst their banks today and tomorrow.
Photo 1 - I cut out a polystyrene base to sit under the part of the structure on tera firma, and to attach the retaining wall to.  I glued this to my 2mm MDF base.  I glued all my bearer piles to the bottom of the bearers and test fitted them into my 5mm holes.
Photo 2 - I taped a piece of lunch paper over my plan and cut and spot glued my joists to the plan.  I cut the pieces of decking board which sit under the structure to size and glued these in position.  There will be some of this visible in the central quad of the structure and behind the structure, but all the highly visible decking will be individual boards.  I'm about to start on these individual boards now.
