JL Innovative Design Kit #311 McLEOD SUPER SERVICE
Started by ReadingBob, July 10, 2020, 07:43:39 AM
WigWag Workshop
Really like the color combination, the build is looking great!
-Steven
Jim Donovan
Just got caught up on your build Bob. First class as always and I have already picked up a couple of great ideas. I have watched you make signs over and over and still can not figure out how you make them so perfect. I'll be following from here out.
Jim D
Holland & Odessa Railroad
Quote from: WigWag Workshop on August 17, 2020, 07:58:04 AM
-Steven
Hi Steven!  Thanks for following along and commenting.  I can't take credit for the color combinations (Floquil Reefer White and Floquil Signal Red).  Those were recommended in the instructions and the colors Paul preferred.  That made it easy on me.   ;)
Quote from: Jim Donovan on August 17, 2020, 06:28:11 PM
Jim D
Thanks Jim!  Glad to have you following along.  The next time I update this thread I'll show the little bit of an interior I'm slapping together the for the front portion of the station.   ;)
Bob great choice of colors.  The weathering is right on.  Not overdone just enough to give it that worn look.
An your usual great tutorial.
Hello Bob, catching up on your build thread. As usual a very nice and informative job. I especially liked the way you put the signs on the wood walls. I always pick up some new tips from you on your builds.   Jeff
Quote from: Jerry on August 19, 2020, 08:56:47 AM
Thanks Jerry!  I really have to restrain myself to keep from over weathering something.   ;)
Thanks Jeff!  I just went with the color recommendations in the kit and tried to keep the weathering lighter than I normally would.  I like heavily weathered, old looking structures so this was a departure from the norm for me.  :D
So, where was I?  Oh yeah.  Before assembling the front walls of the gas station I checked for light leads using a small flashlight.  The side windows and front window/door combinations are glued together edge to edge so I wanted make sure to seal any light leaks.  There were a few.
To seal the light leaks I glued some scrap strip wood in the gaps and that took care of the issue.
Nothing nearly as sophisticated/neat as what Jim and Frank have done in their build threads but I mocked up a little interior for the front since there are a lot of windows and I opted to not put blinds in the windows.  The counter is made up of scraps of photo mounting board.  The flooring is just a pattern I printed out from paint and attached to some photo mounting board using transfer tape.  The figure was an unpainted Preiser figure I found in my stash.  He was hired to be the gas station attendant.
I added a small scrap of strip wood painted a light brown to the counter top to represent a cigar box or something along those lines.
And there we have.  An interior so it doesn't look so vacant when the lights are one.   8)
Now I can glue the front of the station onto the service bay.
More in a moment... ;)
I don't recall ever building a kit where the roof was made out of wood.  The scribed side is the underside and I painted that, and the edges, red.  The upper side will get roofing material applied to it so I left that unpainted.  Although the instructions don't mention it I also sanded the edge that will be at the peak so that the pieces will mate together a little better.  I applied 3M Transfer tape to the surface.
I trimmed the 3M Transfer tape with a pair of Friskar Micro Shears.  Those are one of my favorite tools on the workbench.
Test fitting the roof pieces to understand how everything is going to go together and how well it will fit.  With solid pieces of roofing like this I was hoping to make the roof assembly removable to access the lighting circuit.
Starting at the bottom edge I added strips of the roofing material.  Since I wasn't going for heavily weather I skipped the steps where I'd sand the edges down to make them look worn and tattered.  I also didn't lift up any of the edges or apply any patches.
Like most kit manufacturers this one included a sheet of paper as roofing material along with instructions on painting it and cutting it into strips.  I tossed that and opted to use some roofing material I picked up at the EXPO in Scranton.
I cut the roofing material into 3' wide strips and then removed the backing from the 3M Transfer tape so I could apply it.
The Friskars come out again to trim the excess roofing material.  :D
Next I very lightly drybrushed the roof with some Folk Art Ivory White.  Very, very lightly.
I wanted the roof to be removed but it ended up not cooperating and sitting in place so I was forced to add a few drops of glue to hold it down.  If need be it could be popped off with a chisel blade.  I only applied the glue to bracing over the service bay.
The LED's were a bit to white for my liking so I painted them with Tamiya transparent yellow which gives softens up the light a bit.
I made a base to mount the structure on.  The paved area is drywall joint compound scribed, painted and colored with pan pastels.  I really did this just for practice as well as to have something to mount the structure on when I mail it to Paul.  He'll be able to pop it, and the other details off, without much difficulty.
For the billboard I ignored the recommendation in the instructions which were to build it first and then airbrush it.  I prefer to paint everything first, then build and then touch up an cut ends.
More in a moment.... ;)
It's a pretty basic billboard and went together easily.  On a totally unrelated topic I wish I would have bought more billboard kits from VectorCut before the business closed down.   :'(
I had to do some adjustments here and there to make sure I got all the supports seat properly and more or less lined up.
So, I mentioned that the structure and details can be removed from the base when Paul gets it.  I used a minimal amount of Elmer white glue to glue it down.
Time for some final pictures after adding weeds, shrubs, details, etc.
 :D
I noticed I forgot to add some of the free standing signs so I constructed a couple of those and added them after the fact.
This has been a fun one.  For the price it's a pretty nice little kit.  Next task will be to get her packed up an in the mail to Paul later this week or next.   :D
Thanks for following along!
That turned out nicely, didn't it?  Great job as usual.
