The Grizzly & Dilapidated Ry.
Started by kyle creel, February 02, 2025, 10:19:09 PM
kyle creel
The comparisons with Malcom Furlow are very appropriate.  Besides the Southwest locale, there's the consistent color palette between the foreground scenery, the backdrop, and the weathering, there's the well done but somewhat fantastical backdrops, and the way the scenery dominates the layout.
Nice, I can't believe it's not paint  :o
kyle creel
#288
Thanx Dave, and thanx Phillip;
I consider it a wonderful compliment Dave, Malcolm was indeed quite the artist.  I do try to have the landscape and scenery 'dominate' to a certain extent- :) since that's how it is in nature...much more 'scene' than trackage- I try to have the 'rural' or 'wild' areas be the star. ;D  ;D ....it's ironic that you should mention 'fantastical' in your description; I went on line to find images of natural 'stone pillar' rock formations ??? and there were literally hundreds of them throughout the world :o  :o  :o - although not so many in the US ??? - which I found odd....but never the less I decided to 'install a couple in the backdrop to accompany the 3D version in the scenery... ;D  ;D I call them "Tres Hombres" 8)  8)  8) ...being a Texan and all (ZZ Top reference intended 8)  8)  8) !!!!!!!)  I call the 3 mountains on the horizon above Grizzly...'Tres Hermanas' ;D  ;D - THREE SISTERS in spanish ;)  ;)  ;) ....I'm very glad you like the look..... ;D
Phillip...thanx for mentioning the medium I use ;)  ;) it's not often noticed.  Almost everyone just 'assumes' it's painted.  I have noted the use of pastels in my posts, and highly recomend their use ....THEY ARE VERY FORGIVING ;)  ;)  ;)  ;D .......
I decided to this morning (Monday) to bring the whole scene we're currently discussing into the foreground a bit :o  :o ...by adding some larger trees TO THE PILLAR and in front of the red cliffs; almost blocking them out - as it would be in nature. 8)....I hope it works, there will also be more even larger conifers in the immediate foreground added as I progress along today.  I work in 'spurts' :o so as to allow the thing to 'grow on me' ;D  ;D .....here's some shots of the thing so far this AM ;D  ;D
Ya'll keep stoppin' by ;D there's always plenty happening at the G&D Ry Co. 8)  8)  8) ...thanx again for all the kind comments and obsevations.... ;)  ;) ....see ya.......
KYLE CREEL
G&D Ry Co.
VOILA!!!!!! ;D  ;D  ;D .......................
PS 8)  8) The great John Allen also had some fantastical looking 'pillars' in his magical G&D world, Malcolm got alot of his inspiration from "The Great Poo-Bah".....................................
Hi Kyle, you're certainly a master at backdrops.  I hope you are having some fun with them.  ~mike
kyle creel
#291
Thanx Mike,and thanx Curt;
I added a little bit more this afternoon (Monday) ;D ...I'm starting to get the 'depth' thing down ??? ...It's been a bit of an issue for some reason ::) ....but I have a plan now and after dinner tonight I'll get back on it..... :o  :o ....stay tuned......and thanx for all the support and 'stop-bys'.......here's some shots of the 'progress'....
KYLE CREEL
G&D Ry Co.
Here we are a while back..........
Today.............................
Hope they look OK ;D  ;)  8) .......chow!!!!!!!!!
kyle creel
#292
OK ;D here's the 'after dinner' bit ;D  ;D  ;D ................
here's where I started...............................
where I wound up.....................................
Up close ;D  ;D  ;D  ;D..........................
overview....................................
Not a bad days' work ;D  ;)  8) ............see ya............................
KYLE CREEL
G&D Ry Co.
DANG THAT LOOKS FANTASTICAL!!!!!! That is definitely a "show stopper". Excellent, excellent work and creativity.
Hello Kyle, the backdrop just keeps getting better and better. Very nice work.
I think you'll want a couple of trees closer to the backdrop, but not as tall, to get a bit of a perspective effect.  But overall the entire scene ties together very nicely!
kyle creel
Thanx Larry C*, thanx Mike, thanx Keff, and thanx Dave;
The backdrop is progressing nicely, I appreciate all the kind words, comments and suggestions; also all the folks that just stop by to look in on what's goin' on ;D .  Everybody's welcome here at the G&D Ry Co. ;)  ;).......
I'm fixin' to move into a little bit more demanding phase of the backdrop project.  Dave touched on it a little in his comment regarding the depth of field and the trees.  This is a shot of how I do 'tree filled corners' that need depth and "camouflage" to hide the 'seam' between 3D and 2d :o  :o  :o .........This is, I realize not a very clear picture, however the principle is evident 8) ....use large or fullsize trees and create matching trees in the backdrop to create a 'clump or grove' and create smaller ones in the distance on the backdrop in the same area to bring distance into play..... ;D  ;D ....I realize that not everyone can 'create' or draw trees, so I recomend using what ever technique will give the best results as Dave mentioned.  Sometimes that means smaller trees next to the backdrop to create forced perspective.
This shot shows the same corner, abit different angle, but with the blue arrows indicating the divide between 3D and 2D, the red arrow denotes the corner.....
Here is the same backdrop corner today (Tuesday evening) still on the same wall ....and it shows a great deal more detail ;).......
and reveals what is possible, this was done in pastels over an acryllic 'land form'....in 2019 :o  8)  8)  8)
I'm going to try and use the same technique on this corner..... :o  :o I will however, change the color of the 'corner styrofoam scenery piece' to match the current surroundings ;)  ;) ......this should be very interesting :o  :o .....I think I've got my plan all worked out ::)  ::) with some allowances for "The best laid plans......" :o  :o  ;)  ;)
Here we go.......I'll keep ya'll posted........stay tuned.................see ya........ ;)  ;)
Kyle, thanks for the great discussion on 3d to 2d and hiding the corner.
