Most of the windows now have glazing.
The 2 paired windows at the bottom go into the attic gables, That's why they're a different casting, with different framing, than the rest of the windows.
I still need to do the door glazing, and the windows for the boiler shop.  But that's small potatoes.  Before I install these, I'll go back and add a touch or two of window glue to the corners, to help lock the glazing into position.  I don't want it to pop out after the structure is assembled.  That would be A Bad Thing.
Dave the windows look great and there certainly are a lot of them; have fun.
Howdy Dave, nice work on the windows, and good luck with the remaining glazing.  Have fun, mike
Dave Buchholz
Thanks for the glazing instructions.
My technique has always been poor. Too much glue everywhere
Fifth Dave to the right.
The kit loading doors are single barn door style.  But that would block the windows, so i wanted to convert a single door to double swinging doors.
The top row is the kit pieces.  The bottom row is the work-in-progress.  I carefully cut the laser cut inner piece in half, using a #11 scalpel blade.  Then I added 1x4 and 1x6 trim.  I cut down the open window back pieces to match the inner doors. I cut clear glazing the size of the door (not shown.)  After I paint the pieces, I'll assemble a sandwich of outside, glazing, inside.  I mocked that up, it'll look pretty good.  I'll need to touch up the paint on the edge after the sandwich glue is dried.  These will open inwards, I may need to do some adjustment to the window trim on the walls.   And I think I have some hinges somewhere that will work well for these.
Dave Buchholz
Quote from: deemery on November 10, 2025, 06:32:56 PM⁶ I don't want it to pop out after the structure is assembled.  That would be A Bad Thing.
I hate when that happens as well Dave
Windows and doors test fit:
The door will need a bit more sanding, etc.  I'll fit the door casting and then apply the external (laser cut) door trim.
Looks great Dave. I like the large upper window.
Looks like a good fit Dave; well done.
These are all parts from the kit (with a few minor adjustments.)   And the kit follows the prototype building pretty faithfully.
Significant progress the last couple of days.  Here's the test-fit of the windows and doors in the acrylic wall:
One (double window) opening was smaller than the others (surprisingly, for a laser-cut kit), so some sanding got that to fit.
I painted the bottom of the 2nd story floor/1st story ceiling white, to better reflect light on the machine shop area itself.  This helped a bit.  Then I glued the 2nd story onto the first story.  The weights help pull out the small bit of warping that painting the wood floor/ceiling produced.
This means "no more fiddling with the machine shop area", but I think everything is reliably glued into position.
Also I installed the windows, doors and trim on the boiler room (3 wall annex).  I'll glue those walls together tomorrow.  And I'll start gluing the windows/doors onto the acrylic.  I need to figure out the right glue for that, the windows are styrene, the trim is wood.
Dave very nice progress and it's coming together nicely.
Dave looks like you proved the first floor is able to handle the weight!!
Looks great Dave. You've done an excellent job on the kit and detailing.
