craftsmankits
Dang Tom. There is so much work to this build.  You'll be on page 50 before it's finished.  Thanks again for all the updates and photos.  Mark
As always, your builds are full of real time solutions. It has always been
a joy to follow your threads. I looked a few pages back and saw cutting, fitting,
odd angles, all of which required engineering, and you accomplished each one perfectly.
Quote from: Rick on June 07, 2026, 05:38:21 PMTom, always a pleasure seeing your progress and engineering.
Post as many photos as you like.  ;D
Rick,
Thanks very much for the comment and for following along.
Quote from: Michael Hohn on June 08, 2026, 08:21:28 PMTom,
The first photo in your latest post is a work of art.
Mike,
Thank you, much appreciated. It seems like there is many opportunities in this build to create a work of art.
Quote from: friscomike on June 08, 2026, 09:22:55 PMHowdy Tom,
Just wow!  It is looking terrific, as usual.
HAve fun,
Mike, Howdy,
You kind comment is appreciated. Thank you.
Quote from: craftsmankits on June 09, 2026, 06:46:05 PMDang Tom. There is so much work to this build.  You'll be on page 50 before it's finished.  Thanks again for all the updates and photos.  Mark
Mark,
Thanks and I agree, there is much work in this one. I'm guessing I will be close to 50+ when finished.
Quote from: Pennman on June 10, 2026, 10:26:38 AMTom,
Rich,
I thank you sir for the very generous and kind compliment on this build. It seems like every kit or build requires some form of adjustments in cuts and angles.
I was finally able to get back to this one. Although I have to admit the break was nice for a change.
After adding all the top plates, I sprayed all three structures (not shown) with the Tamiya Insignia White. This was necessary to cover the yellow hue of the Durham's Water Putty stucco.
These three will be put aside for now while I build some sub assemblies.
I need to build four sky lights.
I'll also need to build the Goodyear billboard sign.
The billboard sign brackets are very fragile. They seems to say, "Don't look at me, I'll break"
Well, I must have looked as one did in fact break when I picked it up.
I'll make this repair using an HO scale 1X4.
I applied the first coat of Tamiya Lacquer Yellow to the Goodyear sign. The lacquer is very thin and the first coat soaked into the wood. It will take a second coat. I'll add the second coat once this dries and cures.
I also painted the billboard frame with Tamiya Lacquer Flat Blue. I'll finish the billboard brackets tomorrow.
Done for today.
Glad to see you back at it (and that the excess water didn't do any lasting harm to your train room....)
Tom always good to see you posting on this project.
Glad the room is drying out.
Great to see you at it again. Those pieces look beyond fragile but I know you'll do another perfect job.
Tom, nice to see you back making progress on this project.
That sign is going to look great.
Nice to see you at the bench again.
I see you had a typical "another problem, another solution" with the sign.  I'm pretty sure that once the repair is done, you would never know it was broken.  with the colours you have chosen, the sign will look great when completed.
