CCK Lucama Fish Camp - Challenge #1
Started by ACL1504, September 12, 2016, 04:22:59 PM
In order to determine the height of the pilings, I used a metal bar and measured from the river bed to the bottom of the bar. The height was 1 1/2 inch.
I then cut ten 1/8 " dowels to that length. Two of the dowels/pilings were glued to the bottom rear of each happy hut/shack.
I forgot to mention that I stained and glued scale 8 X 8's to the bottom of each shack.
I'll work on the dock ramps and dock next. Cross bracing and horizontal bracing still needed.
PaulS
Your happy huts are coming along great Tom !!   This ugh to be quit the scene when it all comes together.
--Paul
Quote from: PaulS on September 18, 2016, 07:09:09 PM
--Paul
Paul,
Thanks very much. I'm really excited to get moving on this area. I plan on having it finished by the end of October of this year.
Today I worked on the dock for the fishing shacks. After building the dock frame, stringers and planks I noticed some glue squeezed through a few of the planks.
I used an Emory board to remove the glue spots. I used the white side of the board and gently removed the glue. I was so pleased with how the planks looked after the sanding I used the Emory board on the entire dock planks.
I used the white side on Delwin's docks also.
Break time, back in a few.
Finished the dock with pilings, cross  and horizontal bracing. When the glue dried I touched up any exposed lumber ends with A&I stain.
I also added the dock approach ramps.
Raymo
Quote from: ACL1504 on September 19, 2016, 04:19:03 PM
Boy! That adds another layer to weathering! :D
Quote from: Raymo on September 19, 2016, 04:28:54 PM
Raymo,
It sure does, I'm surprised I never thought of it before. Well, I didn't think of it this time either. 8) 8) 8)
Just trying to get the glue off and whaalaa!
martin.ojaste
Tom, it is coming along quite well. The dock brings it together.
The dock decks are looking great , board by board is certainly paying off.
Quote from: MartyO on September 19, 2016, 04:32:36 PM
Marty,
Thanks for checking in. Yes, the docks do seem to make the scene complete - for now anyway. I have more details to add.
Quote from: Janbouli on September 19, 2016, 05:03:43 PM
Jan,
I appreciate the kind words of support for the build. The board by board adds a touch of realism to the scene.
I applied the horizontal and cross bracing to the fishing shacks today.
I'll be adding the roofs next.
