Wow, you're getting a lot of work done.  Thanks for the reminder of the hot glue Tortoise installation.  It's been so long since I did my last one, I'd forgotten it!
Quote from: Zephyrus52246 on July 03, 2014, 07:44:37 AM
Dr. Jeff,
Yes, I've been a busy little worker the past week or so! Thanks for stopping by, much appreciated.
Tom....
The idea of hot gluing the switch machines is a super idea.
Thanx
Erieman
Good Afternoon Tom,
I took a break from picking pods and started digging a tench for buried irrigation lines to a couple of new trees. I must be absolutely nuts to be doing this stuff this time of year. It's @*%ing hot out there. so here I sit, computer in my lap, sweating like a dog, the fan blowing on me to cool me down, typing this post.
Absolutely great job on the ovalix. And I like the way you mount the switch machines. Russ and I do something similar. If I could be so bold, may I make a suggestion. Instead of using super glue to fasten the brass rod to the plywood, use hot glue there as well. No waiting, or very little at best..Just don't burn you fingers!
Another 110 degree day here in the desert, so I will be in the train room for the rest of the day! Yes, more shingles. I think I can finish one side of the station.My wife keeps coming in to make sure that I am still alive ( sound familiar) and always asks when and if I am going to vacuum the floor. AFTER the shingles are all done!!!
Well, back to it. Keep up the beautiful work. Can't wait to see the three levels as they branch out from the corner. Go build a structure!
Frank / Erieman
Quote from: ACL1504 on July 03, 2014, 07:38:50 AM
Quote from: S&S RR on July 02, 2014, 09:34:32 PM
You have been very busy- it is looking great!
Yes, I've been busy on this. I need to get it finished so I can build a structure!
So define finished? If you feel like building a structure for awhile then just do it.
Quote from: bparrish on July 03, 2014, 02:32:27 PM
Tom....
Thanx
Thanks for stopping by for a look see. I came on the hot glue for Tortoise machines when I was under the layout, upside down, in some exorcist body twisting mode, trying to hold the machine in place and at the same time screw it in place. The hot glue solved all those issues! :P :P :P
Quote from: Erieman on July 03, 2014, 02:35:27 PM
Good Afternoon Tom,
Frank / Erieman
Frank,
Morning Frank and Happy Independence Day!
Thanks for the comment. I actually forgot to mention that the CA glue was to hold the linkage in place while I tested the machine and linkage. It's kind of scary how we are so much on the same page. I did in fact go back to the linkage and "hot glued" the linkage in place after I was satisfied with the operation aspect of the mount. In the past, I've found it much easier to remove and fix a badly aligned linkage with only the CA glue as opposed to taking a plier and removing it! I'll be sure and add this info to the thread in my next post. Again, thank you for the reminder.
Quote from: S&S RR on July 03, 2014, 09:52:56 PM
Thanks for the visit, much appreciated. By "finished" I meant I wanted to get the ovalix finished before starting a structure build. And while I'm building a structure, I can then move on to the rest of the bench work.
Shoudln't you be building something?
Quote from: GPdemayo on July 04, 2014, 09:50:15 AM
Yes sir, I'm building an ovalix!
Tom ;D ;D
Looking good, Tom!  My you've got a lot of work done!
Quote from: mark dalrymple on July 04, 2014, 05:57:49 PM
Mark,
Thank you, very much appreciated! More coming soon to a thread near you!
In one of the last posts, Erieman, Frank Baker, mentioned that he would also add a little hot glue to the copper tube to hold it securily in place. I actually did this but I didn't mention it in the thread. Anyway, here is a photo of what I did. I used CA glue and a spot of hot glue.
Here are a few progress photos. No narrative necessary - I don't think!
Tom, aren't you worried about bumping into that Tortoise jutting into the center?  The layers are going up pretty quickly, nice work.
