Quote from: Rick on August 04, 2025, 07:41:29 PMTom, decals look good.
That's a real nice drill press you have there.
Rick,
Thanks my friend. This is the first time in four years I've pulled the drill press out.
Quote from: Jerry on August 04, 2025, 09:47:33 PMBeautiful work Tom!  And a nice little drill press.
Jerry,
Thank you on both for the compliments.
Quote from: tct855 on August 06, 2025, 12:24:14 PMACL1504~,
        KPII; Awesome yellow metal Cabeese paint thread brother!  Enjoying it with great alacrity brother!
        KP-out...
Brother Thommy,
Happy to have you following along KPI. Your quick-witted comment is appreciated also.
KPII
Yesterday, I found time to paint the trim on the cabooses.
For the side hand rails, I slip a piece of paper under them and paint reefer yellow. In this case the yellow is Floquil Reefer Yellow.
For the rest of the yellow, there is no easy way. Just use a small brush, don't load the brush with a lot of paint, be patient and take your time.
The two brass cabooses are imported by Overland and both are Seaboard.
I wanted the marker lights located differently on both, so on the SAL caboose, I have it with the cupola forward and the A&S with the cupola in the rear.
Next, I'll install the window glass and then move on to the installation of the lighted marker lights.
Done for today.
I'm following you on this, as I have a couple of cabooses which need dressing up.  Marker lights are part of that, so they'll trip my occupancy detectors.  I had done an RR-Line thread on installing Tomar markers in a Centralia caboose, but haven't recreated it here.
Quote from: jbvb on August 07, 2025, 03:10:46 PMI'm following you on this, as I have a couple of cabooses which need dressing up.  Marker lights are part of that, so they'll trip my occupancy detectors.  I had done an RR-Line thread on installing Tomar markers in a Centralia caboose, but haven't recreated it here.
Maybe you should!
Hello Tom, your cabooses are looking great. The yellow handrail painting tip is new to me and I'll have to remember that. Thanks.
Tom, those yellow handrails look very good against the red.
Really makes them pop.
Neat trick with the card.
James,
It's to bad we didn't get more notice of the RR lines shutting down.
I found my thread here I did back in 2016. It all still applies now.
Quote from: Jerry on August 07, 2025, 04:01:38 PM
Maybe you should!
Jerry,
I thread on this subject would be good. I did one back in 2016 on this forum. I'll take some of that thread and redo it here.
