Quote from: Pennman on July 30, 2025, 03:17:56 PMThis caboose will be a stunning model once completed.
Rich,
I sure hope so, thank you.
Quote from: deemery on July 30, 2025, 06:00:41 PM
Quote from: ACL1504 on July 30, 2025, 12:52:31 PM
Quote from: Jim Donovan on July 29, 2025, 08:47:11 PMHi Tom;
It has been awhile since I checked in. Great tips on the caboose rebuilds. The airbrush still showed some paint after all you did to it, must have been really coated. I find if I don't keep mine shiny and clean it simply does not work. Results looked great.
Jim,
Welcome back and good to see you. The red on the airbrush is a reflection from my red shirt when I took the photo.
Thanks for stopping by and leaving a comment.
Gee, Tom, you know the consequences of wearing the red shirt, right?  https://en.wikipedia.org/wiki/Redshirt_(stock_character)  :P  (On my big project of the '00 decade, "Who has the Red Shirt for that presentation?" was how we tagged the person responsible for giving a briefing...)
I remember that Star Trek episode.
I attended an officer's retirement and was wearing a red shirt. Yepper, I got called on to give an impromptu speech.
I finished decaling the two cabooses. I didn't add any build dates or other data, just kept it simple.
After decaling I sprayed a flat finish on the A&S caboose.
I still need to paint the handrails yellow and add some black to the ladders.
I did the same for the A&S side door caboose, kept it simple as well. This one is now in revenue service.
In order to add the marker lights, I needed to drill two holes in the bottom of the floor plate. This will also become more clear later in the thread.
I used my Micro Mark MicroLux variable speed drill. I keep two metal drill bits for this occasion. The for drilling the floor is 1/4 inch. I'll cover the drill bit for the caboose markers later as well.
I likie to have the brass on a softer  surface so I use a small piece of 1X4. The brass bottom is placed on the wood and then the hole is drilled between the floor braces.
Once the holes are drilled, I use a slightly large bit and hand twist it over the drilled holes. This removes and brass burrs.
The base floor was cleaned in Acetone (outside to avoid any fumes).
When dried, I sprayed black with Scalecoat paint. I placed it in a baking pan and let the sun bake the paint.
I repeated the process with a flat finish. The red plate is the brass models builder. The importer was Overland Models.
The unpainted brass is where I held the piece to paint. This will be covered by the coupler pocket and won't be seen.
Done for today.
Tom that is one sweeeeeet looking caboose; looks great on the layout.
                            2025 Winter Callenge
VERY NICE looking cabeese!
I usually put a piece of thin plywood (laser-cut kit sprues...) underneath stuff when I'm drilling.  I also use that stuff to construct little assembly jigs when gluing styrene.  (And I use cut-off pieces of styrene for jigs when assembling wood.)
Howdy Tom,
A man and his toys.  My wife is amazed at me having so many "tools", but you must have them to model on the periphery.  Nice work on the caboose.  It's a beaut!
Tom, decals look good.
That's a real nice drill press you have there.
Beautiful work Tom!  And a nice little drill press.
tct855
ACL1504~,
        KPII; Awesome yellow metal Cabeese paint thread brother!  Enjoying it with great alacrity brother!
        KP-out...
Quote from: Larry C on August 04, 2025, 03:08:17 PMTom that is one sweeeeeet looking caboose; looks great on the layout.
Larry,
Thanks very much. After these two are finished, I'll be done with all the brass caboose painting.
Quote from: deemery on August 04, 2025, 04:45:58 PMVERY NICE looking cabeese!
I've used plywood in the past as well. The 1X gives me some drilling space. The jig idea is a great one.
Quote from: friscomike on August 04, 2025, 05:56:31 PMHowdy Tom,
Mike, Howdy,
Yes, toys and the man! Tools are just another aspect of enjoying this great hobby.
Thank you for the nice comment.
Tom, still having fun.
